07-12-2011, 08:44 PM | #21 |
Pebble Pounder Join Date: Feb 2010 Location: yankees suck
count me in the interested crowd. want to make my mini into more of a scaler with speed. but dont have the budget to order parts that dont fit, so subscribed. for the vxl motor mount, there are two sets of holes: brushless 19mm apart for 3mm screws, brushed 16mm apart for 2.5mm screws and the brushed mini summit comes with a 540 motor mount! which of course it can be bought separately. someday ill be doing 30 mph backflips on flat ground....but anyways hope this helps Last edited by jaytet; 07-12-2011 at 08:46 PM. Reason: added subscribed |
07-13-2011, 11:23 AM | #22 |
Rock Stacker Join Date: May 2011 Location: At the bottom and heading to the top
hey guys that sounds like a sweet idea! i have my old RTR just sitting around and was thinking about making a scaler with it what if you were to make your own tranny like Gerry has in his thread thunder_ warm with LCC axle? Smiles |
07-13-2011, 12:36 PM | #23 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
I guess you could make a Tranny Yourself..but for $13 bucks for the Traxxas tranny..saves a lot of time. Plus it has everything included, spur, slipper, motor mount. etc...
07-13-2011, 12:43 PM | #24 |
Rock Crawler Join Date: Oct 2010 Location: Reno
Great idea smiles. Skullking. You maybe onto a great find. I really can't wait to here what you come up with. |
07-14-2011, 03:28 PM | #25 |
Well got the traxxas mini tranny in today. Looks good. I will post pics later. All steel gears....heat sink motor mount....spur gear cover. Driveshaft outputs same dia. as the losi, but the traxxas ones have the hole all the way through which i like better than just a set screw anyway. 1st off the center of gravity with the motor is going to higher....but I do not care about that. There are 4 mounting holes. Thinking of using spacers to the skid. Just going to go with the traxxas brushed 380 motor for starters, but I have 2 motors from a 1/8 nylint that bolt up perfect. They have torque if they can push those big ass rigs around. Should be interesting what kind of speed I get with the gear ratio of the losi axles. Anyway when my wife gets off the computer I will post pics.....
07-14-2011, 03:34 PM | #26 |
You got that fast skullking. I'm so antsy to see if it works. Do you have anyway of measuring the top speed? I just ran my MRC in the treadmill to get a mph reading. But with less gear reduction and big motors I think you may need to fallow it in a race car. Lol.
07-14-2011, 03:52 PM | #27 | |
07-14-2011, 05:01 PM | #28 |
Fair enough.
07-14-2011, 07:11 PM | #29 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
Lets see a video!
07-14-2011, 07:43 PM | #30 |
| WHAT I dont even have this rig put together yet.....Here are some pics of the New Tranny.... I stand corrected the Tranny Gears are NOT all steel, just the idle gear is steel the rest is heavy duty plastic. Still is holds up the Brushless this is a tranny from a VXL mustang. I just checked the website for specifics.... She is all locked up to, no diff locker just a one peice gear. Last edited by skullking; 07-14-2011 at 07:58 PM. |
07-15-2011, 10:26 AM | #32 |
I have not seen a brushed trans on ebay let's us know when you do...
07-15-2011, 11:34 AM | #33 |
Skullking. Just to clarify for myself and others who don't own traxxas mini vehicles, the transmission you are using for this conversion is from a brushless mini and is not the same transmission as the 540 brushed transmission also available in the traxxas minis?
07-15-2011, 05:40 PM | #34 | |
07-15-2011, 07:36 PM | #35 |
I kinda thought that my mrc was a rock racer |
07-15-2011, 09:07 PM | #36 |
07-15-2011, 10:51 PM | #37 |
07-16-2011, 04:49 AM | #38 |
| What are you using?? for your speed and torque? Yeah I do not care about the COG. just having fun building it |
07-16-2011, 07:58 AM | #39 |
Rock Hard. I've heard nothing but good things about your motors. Heard the are extremely powerful and smooth. I've never had the pleasure of seeing one run, but I would guess they are pretty fast also with a 17, 18, and 19 turns. If I had to guess your motors probably produce the kind of speed we are all wanting. With at the tranny gear reduction I bet your motor gets really hot and sucks the life out of a battery rather quickly. I would think if the if the traxxas transmission skullking is working with is roughly half the reduction the stock MRC transmission is that it would cure the heat issue. Your powerful motors would still be a prime contender for this type of build.
07-16-2011, 08:16 AM | #40 |
ooooooo...hybrid buildI just got some 1.9 RC4WD Mudslingers mounted up on stock Losi Pro beadlocks. One side is easy but the other is a Pain in the A$$. I also got the long screws needed for the tranny mount. They are 3MM. I just need to get a peice of Mock up Acrylic or something to make a skid. Gonna half to use 4 long spacers. Also I got my driveshafts ends drilled through so I can use the traxxas set screws. Pics Later.....
