Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Install bent links on mrc pro?
Old 07-13-2011, 11:11 PM   #1
Default Install bent links on mrc pro?
Question. I have some links to install yet looking at the lowers I can't see how to remove/ install the old and new from the chassis. The screws I see don't "match up" with the end. Any suggestions?
Manfjourde is offline   Reply With Quote
Old 07-13-2011, 11:14 PM   #2
I haven't had mine apart yet, but some chassis requires you to remove a sideplate to gain access to the link attach on the skid.
Charlie-III is offline   Reply With Quote
Old 07-13-2011, 11:22 PM   #3
If i remember correctly...You do in fact have to take the side plate off to change the links. Some good pics here. you can see where they come out on the skid
http://forum.losi.com/showthread.php?t=4385&page=5
maeu2003 is offline   Reply With Quote
Old 07-14-2011, 07:12 AM   #4
Really? I just took one small screw out of the skidplate and pushed the pin through from the other side. Changed out my links and put it back in the opposite way I took it apart.
relic68 is offline   Reply With Quote
Old 07-14-2011, 08:46 AM   #5
Do you have any pics or more light to shed on the situation...?
Old 07-14-2011, 09:18 AM   #6
I'll post one up here in a few.
Old 07-14-2011, 09:24 AM   #7
The small screw comes out and then push the pin from the other side.
Old 07-15-2011, 06:53 AM   #8
My rig is ~1200 miles from me. Pulling the screws to get to the pin is about what you would need to do to remove a side plate.
Either way, not too hard.
Old 07-15-2011, 09:39 AM   #9
Right on, thanks guys. I'll hopefully give it a shot today!
Old 07-16-2011, 01:26 PM   #10
I'm changing links also, but have another problem. How do you remove the rod ends from the stock link (MRC pro) that attach to the chassis? The ones attaching to the axles threaded off no problem. The other ones keep spinning but don't cone off, not even whel pulling. I noticed the rod has grooves near the axle, is the other end not threaded?
It happened on all 4 lower links.
GWEEDZ is offline   Reply With Quote
Old 07-16-2011, 01:30 PM   #11
Thats because they are left handed!
Old 07-16-2011, 01:36 PM   #12
LOL! What an idiot I am!
If I come up with any other dumb questions, I'll be sure to keep them to myself!
Old 07-16-2011, 01:38 PM   #13
It's all good, we all have moment's of stupidity! I won't haze you too bad on here.....lmao!
Old 07-16-2011, 01:40 PM   #14
Just changed my Rear Lowers out for Bents.. it's barley a 5min Job...I'm using HR Bent Lowers. Just remove the rodend from the axle. Rotate it is the Link comes out of the Rodend at the Skid. Remove the other Rodend from the Old link. Installl it on the new one. Then Just thread the new bent link into the on at the Skid.
Old 07-16-2011, 01:47 PM   #15
I have the HR links, bought used. I didn't know they wouldn't come without the threaded insert. So now I have to buy threaded rod, plus 2 more RH thread rod ends. No 5 min job here :(
Old 07-16-2011, 01:48 PM   #16
This may sound silly... but why use bent links on the MRC Pro? The stock links run right to the main diameter of the wheels and are almost perfectly in line with the axle... I ask because the only reason I know of to use bent links is to allow the tires to catch before the frame does and the stock links are in such a position as this isn't necessary on the MrCPro.
Evilinside is offline   Reply With Quote
Old 07-16-2011, 01:56 PM   #17
I got them cheap.
Looks cool.
I'm hoping it will clock the axle enough to raise the axle pinion so less chance of catching.
Old 07-16-2011, 02:07 PM   #18
They really don't clock the axle much, move the upper's one hole forward on the rear axle.
Old 07-16-2011, 02:20 PM   #19
Originally Posted by GWEEDZ View Post
I got them cheap.
Looks cool.
With Bent Rear Lower Links and the Axle is rotated up and out of the way...An easy 5min Job...
Old 07-16-2011, 04:20 PM   #20
Is that a just for fun thing, or are you trying to gain a benefit from that? If so, what benefit?
