07-24-2011, 01:45 AM | #21 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
This one appears to be 8.5, that's why I mentioned it. |
07-24-2011, 01:48 AM | #22 |
07-25-2011, 11:09 AM | #23 | |
Rock Stacker Join Date: May 2011 Location: At the bottom and heading to the top
thanks smiles | |
07-26-2011, 12:54 AM | #24 | |
http://www.jpcustomrcs.com/catalog/i...71/8921874.htm And this kit for it's 5mm Spacers... http://www.jpcustomrcs.com/catalog/i...71/8921876.htm | |
07-26-2011, 10:49 PM | #25 |
Small update: Got my Radio GT3B from Losikid with it already HACKed... Also got the Holmes Motor and Stock ESC installed. Got everything wired up and tested it on the Floor. Steering isn't set up yet. So I didn't get to test to much... I can already tell this set up is mush smoother running then my last MRC with the Monogoose Brushless system. It always seemed jumpy to me. This set up is way better.. Going to try and get the body painted tomorrow and the steering figured out. |
07-27-2011, 06:36 PM | #26 |
Ran it today with no castle BEC... Ran fine and climbs good. But the Servo Sucks.. Wouldn't turn unless I was on the throttle a little. Think I'm going to try a Hitec HS-7940TH 6v........................7.4v Speed: 0.07 sec...................0.06 sec Torque: 181 oz/in...................222 oz/in |
07-27-2011, 06:44 PM | #27 |
Sucks to hear about the servo.
07-27-2011, 07:55 PM | #28 | |
07-27-2011, 08:10 PM | #29 |
| The 7940 is much faster then the 7955.. 7955TG
07-27-2011, 08:37 PM | #30 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
| I have a 5955 on my daughters MRC and at at 6 volt it's plenty fast. Personally, I run at the minimum a JR 9100t on my mini. I was running a 8711HV on it, but I couldn't get enough run time out of my TP 325mah batteries. I know some people want the smaller size. I want to be able to steer no matter what.
07-27-2011, 09:11 PM | #31 | |
Neither is a bad choice. You have your ideal servo, I have mine. At the end of the day, if it makes you happy it's all good. For a go fast, speed has more importance, in a crawler, I doubt I would see/feel the difference. | |
07-27-2011, 11:00 PM | #32 |
| The reason I want speed is for wiggling the front around. Since these don't have Digs. A fast wiggling of the Servo can move you around pretty good. With 220oz of Torque I think it can still steer a 1.9'er around just fine. There are a few running the Fub. Low Profile and it doesn't even have 130oz of torque.
07-29-2011, 03:46 PM | #33 |
Got the body painted... Not perfect, but still came out looking good... |
07-29-2011, 03:53 PM | #34 |
Quarry Creeper Join Date: Jun 2010 Location: NIXA
Hey Jarod did you use a template for the black rip's on the body?
07-29-2011, 03:59 PM | #35 |
07-29-2011, 04:39 PM | #36 |
Thanks for sharing that info Jarod!
07-29-2011, 05:53 PM | #37 |
99% Done... Just got to mount the Battery now.. |
07-29-2011, 06:25 PM | #38 |
Forgot to add the info on the wheels... The Front Wheels are Alumn. Hot-Racing Wheels. They have a little more offset then the stock wheels. So I had to remove the 5mm Wideners. The Rear wheels are the stock plastic ones painted black. I did this to keep the weight more forward. If I put the Alumn wheels on the rear. I would have to add weigth to the front wheels. Which adds more stress to the CVD's and robs power... I'll try this set up for a while and see how it works out for me. |
07-29-2011, 06:47 PM | #39 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Looks good Jarod, I like the paint. Can't wait to whup up on it! |
07-29-2011, 07:31 PM | #40 |
