07-17-2011, 05:21 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: olathe
| uh could use some advice
i took my mrc pro pretty much all the way some i could lube up the axles and the gear box. during the disassemblement i never once turned or messed with the links but know after i have out it together the axle i clocked forward quite a few degrees. im not to fond of it but i do not see where i have gone wrong? i will post a pic in a few minutes of my issue Last edited by boneskid1; 07-17-2011 at 05:36 PM. |
07-18-2011, 08:36 AM | #2 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
You might have the C hubs on the wrong sides! Take the wheels off, then the steering knuckles, swap the C hubs around until you see the top "arm" of the C hub on each side is further back than the lower "arm". That should sort it. On a side note, if you want to clock back further, you can file new flats on the axle, then fit the c hubs, drill 1mm hole for the screws and refit, more clocking can help steering in sidehilling and uphill stuff. |
07-18-2011, 08:47 AM | #3 |
thanks for your answer and your right i believe because while i was looking at it last night the c hubs would have been the only thing i could of messed up and thank for the advice on clocking it some more
07-18-2011, 04:24 PM | #4 |
thanks for the help that exactly what the problem was i pretty stupid for not realizing that
07-18-2011, 10:03 PM | #5 |
