07-19-2011, 07:50 AM | #22 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
what if I shipped you a spare mrc rig for mock up and testing? needs an esc to complete. make some parts fly out the door faster? |
07-19-2011, 08:08 AM | #23 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
Definitely game for the shock/link mounts. Are you thinking somthing similiar for the rear axle?
07-19-2011, 08:40 PM | #24 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| sweet!
I will definetly take a set of those, just tell me when and how much and i will buy it all including the knuckle weights! |
07-19-2011, 08:58 PM | #25 |
Rock Stacker Join Date: Mar 2009 Location: St louis
| Both
Im in for a set and knuckle weights too.
07-25-2011, 10:26 PM | #26 |
07-25-2011, 11:35 PM | #27 |
I'm still in..These look good.
07-26-2011, 12:34 AM | #28 |
Quarry Creeper Join Date: Jul 2006 Location: PDX
I'd buy a set.
07-26-2011, 12:39 PM | #29 |
RCC Addict Join Date: Oct 2008 Location: 209
i need 2 compleet with weights and the berg tubes when there ready |
07-28-2011, 10:13 PM | #30 |
| A quick question for you, D-lux:
Are you using a MRC CVD shaft with a LCC CVD stub? I thought the weak spot with the MRC CVD's was the shaft at the "neck" where it thins down. Did I miss something? |
07-29-2011, 11:03 AM | #31 | |
I am not sure what youre getting at? The purpose of this mod is to give you a stronger stub, knuckle, C, no flex in the axle housing and the opportunity to run knuckle weights. If youre having issues with breaking your inner shaft then that is totally something separate. | |
07-29-2011, 02:07 PM | #32 |
JeremyH just pointed out that you can buy this kit for $39.95 http://www.losipartshouse.com/servle...it-cln-/Detail It looks like it will only be a couple bucks more expensive than buying individually and you get a whole lot more. |
07-29-2011, 02:31 PM | #33 | |
07-29-2011, 07:28 PM | #34 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
So you basically just shorten and grind the inner CVD shafts to make them fit in the MRC, or is there more to it than that?
07-29-2011, 07:40 PM | #35 | |
If you want a LCC inner shaft you will have to shorten and grind. Edit: Sorry, not a stock dog bone MRC shaft but a CVD MRC shaft | |
07-30-2011, 07:20 AM | #36 |
| The diameter of the shaft needs to be reduced if you plan on using the existing bearings. If not, then shortening and flat spotting the inner should be all you need to do... |
07-30-2011, 08:37 AM | #37 |
| Thanks Jeremy, have a part number for the replacement bearings? If I'm upgrading to get more beef, I don't want to reduce it back down to stock diameter, kinda defeats the purpose.
07-30-2011, 09:02 AM | #38 |
| Nope, sorry. I had my inner shaft turned down to use the stock bearings. I think if you left the OD the same, then the difference between the OD and ID of the bearings would be too small and they'd easily fail. You can try using no bearings in them and simply let the shaft sit in the locker on one end, and let the knuckle hold it in place on the other. I believe this is what Erik does.
07-30-2011, 06:34 PM | #39 |
Relaxed ! Join Date: Apr 2009 Location: On the road again !
so i got a little package the other day from erik and am exstatic to be able to test this little product that will have a huge gain on the mrc ! now i just gotta get in the shop and get to work! thank you D-LUX FAB for the products you continue to produce! i will have a build up/rebuild section here as soon as i can! |
07-30-2011, 07:41 PM | #40 |
