08-30-2011, 03:12 PM | #61 | |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
08-30-2011, 06:47 PM | #62 | |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Wes | |
09-01-2011, 09:17 AM | #63 |
Erik, If you need any help testing, all you have to do is ask. |
10-10-2011, 01:16 AM | #64 |
Here is a copy/paste from my vendors thread on the shock/link mounts. In 53 willys pics you can see that he figured out that you can use the shock mount in place of the adapter. So, the good news is that you can skip the adapter entirely on the front if you want to run the shock/link mount. It will serve the same purpose as the adapter. I do believe that he is running that shock/link mount without the set screws top/bottom, just a press fit as many are finding. You will still need to cut off your stock shock/link mounts to make this work. Again, you can run just the shock/link mount that I make or if you dont want to do that mod you will want just the adapter mount. Before it was thought that you needed both which is turning out to not be true. Oh, also another cool thing about running them this way is that you can clock your chub in increments with all those holes in the mounts. Before you would have to take the whole adapter off and do new set screw holes. On the shock/link mount you set it and forget it. 53 also figured out that you can simply run these shock/link mounts on the rear. They are a simple slip on and then like the front, you need to cut the stock shock/link mounts off. He also went custom and set them in sideways to the lockouts. Another option would be to do just like the front and do set screws on the top and bottom. I dont have any pictures of the new shock/link mounts for the rear but they are a simple design that does not have all of the holes like the fronts do. You dont need the clocking ability as you just set them where you want anyway. This will really keep the cost down as most of the cost of the mounts are from all those tiny holes. I hope this makes sense and is not too confusing. If there is any confusion at all please post up or PM me and I will see if I can clarify. |
10-10-2011, 01:18 AM | #65 |
Here are 53's pics... |
