07-28-2011, 05:12 AM | #1 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Papabash's Mini Moonbuggy
Since 1.9 has become my favorite class, I decided it was time to do a thread on my comp rig. Here are some specs: Chassis: T1E Mini Moonbuggy Wheels: Motoworx UFO's (custom heavy fronts) Motor/ESC: Novak 18.5 Mongoose System Servo: Hitec 5645mg Tires: Rovers with Nova single stage soft foams Shocks: DTX Vendetta Transmission has all metal gears including spur Traxxas overdrive mod Metal lockers throughout Losi CVD's Clocked C-hubs for caster Home-made Delrin "shark fin" for easier flipping over when upside-down On to the pics: It's definitely time for some new body panels when I get a chance! Decent Steering after clocking mod: Backside of "normal" UFO wheel: Backside of "heavy" UFO wheel: Weight of normal wheel: Weight of heavy wheel: The UFO wheels have been discontinued for quite a while now, but Jake still had the files and fixed me up. Thanks Jake! I absolutely love the looks of these wheels and they were without doubt the easiest wheels I've ever mounted tires to. The extra weight in the fronts meant that I only had to add 1 ounce of very thin lead to get them to the weight I want which means the foam still has virtually all of it's original compression left. Last edited by papabash; 08-04-2011 at 05:25 PM. |
07-28-2011, 05:42 AM | #2 |
One of the Cleanest 1.9's I've seen.
07-28-2011, 06:41 AM | #3 |
Nice looking rig. Did this start as a MRC Pro, or a regular MRC? The shocks, are they 4 fronts, 4 rears, or a mixed set? I don't know enough about them to know. |
07-28-2011, 10:14 AM | #4 | |
This one started out as a regular MRC, way before the price dropped on the Pro. The shocks are rears on all 4 corners. | |
07-28-2011, 10:43 AM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: NIXA
What's the difference in offset between these wheels and your vp's (how much did your width on the front change)
07-28-2011, 11:33 AM | #6 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
Nice looking rib down the center. Were you having roll over issues without it?
07-28-2011, 01:03 PM | #7 | |
In fact, it works so well that I ordered a sheet of Delrin so I can make one for my Bully. Last edited by papabash; 07-28-2011 at 01:40 PM. | |
07-28-2011, 01:25 PM | #8 |
| Austin, the Motoworx wheels have 2mm less offset than stock, so it makes the rig 4mm wider overall, or about 5/32". I just checked my UFO's and they have the same 2mm offset as the newer wheels. The VP wheels appear to have the same offset as stock.
07-28-2011, 01:32 PM | #9 |
Thanks Dave, I like the look of your new rim's they kinda remind me of some old school wheel's |
07-28-2011, 01:38 PM | #10 |
Yeah, I never thought of them as looking like wire wheels, but I see it now. I think I fell in love with them just because they are so different; I've only seen a couple of other threads with them on rigs.
07-28-2011, 01:46 PM | #11 |
Are you going to add any more weight to it?
07-28-2011, 01:50 PM | #12 |
I hammered out a piece of lead wire so it is about 1/2" wide and 1/32" thick and wrapped it once around each front wheel. It made it just about exactly an ounce heavier, right where I wanted it. It is so thin that it doesn't affect the foam in any way.
07-28-2011, 02:10 PM | #13 |
Never thought of using wire for wieght, may have too try that next time.
07-28-2011, 04:10 PM | #14 |
07-28-2011, 04:15 PM | #15 |
07-28-2011, 07:14 PM | #16 |
The lead wire I have really isn't wire, it was actually made for fishing in rivers with fairly strong current. It's about 1/8" in diameter; I bought it in Oregon several years ago. I don't know if they still make it or not but it works great, especially when hammered out.
07-30-2011, 06:43 AM | #17 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
With the extra ounce of lead on your fronts, that puts you at almost the exact amount of weight that I found to be the sweet spot on my mini moonbuggy, too. Nice rig! |
07-30-2011, 08:35 AM | #18 | ||
