08-02-2011, 01:38 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
| MRC Pro
Quick question, the info on the MRC pro says to use a brushless setup with it. Can I just swap my electronics from my mrc to get by for a while? I dont see why the stock motor and esc shouldnt work.
08-02-2011, 01:43 PM | #2 |
No reason why you couldn't. I don't run brushless.
08-02-2011, 01:51 PM | #3 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
The axles and tranny are the same in all the MRC's, just the Pro has upgraded lockers and cvd's. So to answer your question, yes, you can run the electronics from the standard mrc in the Pro. |
08-02-2011, 07:45 PM | #4 |
Newbie Join Date: Jun 2011 Location: Grand Junction
I would tell you to buy my more expensive setup too if I could trick you into it. Even the guys at Hobby Hut in Junction said that's the only setup that will work with it..."See, it says so on the box..." Pretty sad. You can run whatever you want with it. I'm putting stock MRC electronics on the Pro I just bought for my son because they're cheap to replace. Then buying a 5645mg servo for me and giving him my 645mg.
