08-07-2011, 06:11 AM | #21 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
Mini juice is crying our for Mini-T springs! They work REALLY well on the mini juice, use the softest (Pink) up front, a red (medium) on the rear right, and an orange (firm) on the rear left (to minimise any sneaky torque twist that may remain). This will soften up the suspension lots, really allowing the rog to flow over rocks - just make sure you use about 45w shock oil - too light and they become aweful, too heavy and the rig will be very slow to respond to terrain. Worked for me on my mini juice, G |
08-07-2011, 08:44 AM | #22 |
Rock Stacker Join Date: Dec 2009 Location: Gardner
How does that spring set up work with a stock Pro frame set up? Any thoughts?
08-07-2011, 12:11 PM | #23 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
08-07-2011, 05:52 PM | #24 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
08-14-2011, 07:29 PM | #25 |
Master Rocksmith... Join Date: Jun 2011 Location: Salina
threw a hitec 7940 on here the other day, and man did it make all the difference in the world... all i can say is wow... |
08-14-2011, 07:32 PM | #26 |
is that Overkill? i was actually thinking of getting a 7950th, but debting over it being too over much for the mini.
08-14-2011, 08:22 PM | #27 | |
this servo nearly killed the Mini... | |
08-14-2011, 08:26 PM | #28 |
oh i see, Thanks! man im really digging those rear lowers. look sweet. would you happen to know where they are from? i know that you get the rig used. Last edited by MRCCRAWLER1.9; 08-14-2011 at 08:29 PM. |
08-14-2011, 10:41 PM | #29 |
08-14-2011, 10:42 PM | #30 |
oo thanks |
08-14-2011, 11:28 PM | #31 |
just relocated the ESC and BEC to under the hood for better weight distribution. |
08-15-2011, 08:36 AM | #32 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I am really digging your rig and the mini bj has me itching for one so bad. Then I remember how well my BWD wedge drives and I lay awake at night fighting with my self. Anyway. The reason for my response is this. You gotta do me a flavor and get that rx off the roof of that car! COG baby. If you pulled it out of the case, shrink wrapped it and popped it under the rear uppers you might find it works pretty well. Another idea is the non motor side of the tranny between the lexan and the drive shaft in the back. This should get you some weight savings and get your stuff lower. You might even be able to skin your esc too and get it a little smaller and a little lighter. Just thinking out loud with you! Very cool build regardless. Nice work. |
08-15-2011, 10:43 AM | #33 | |
08-15-2011, 12:31 PM | #34 |
I just went to 2s on a 16t motor so I could ditch the BEC and run my servo straight off the battery. The 325 65c thunderpower packs are impressive and small as all get out. I might suggest trying something like that. You will need the right motor though. RickM |
08-15-2011, 01:35 PM | #35 | |
i got the HH mini torquemaster right now, and its definitely no slouch, even on 2s..., but couldn't resist the last chance to get one of those 17T monsters... | |
08-21-2011, 11:43 AM | #36 |
Just had to see what all the hype was about? |
08-21-2011, 06:33 PM | #37 |
Got em' finished... not bad for my 1st attempt? BEFORE... AFTER Last edited by FlightInstrukta; 08-21-2011 at 11:45 PM. |
08-21-2011, 09:16 PM | #38 |
Those look really nice. What is your final height measurement on them?
08-21-2011, 09:57 PM | #39 | |
this is how much i added... and this is where we ended up... whoops... | |
08-23-2011, 07:08 AM | #40 |
Rock Crawler Join Date: May 2009 Location: Bellaire
Rig is looking good man!I still like the looks of the mini juice chassis. I might have to pick up another one. |
