10-05-2011, 12:18 AM | #41 |
Newbie Join Date: Aug 2011 Location: 425
Nice build, would blue beadlock rings be overkill?
10-05-2011, 06:08 AM | #42 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
I am waiting until I upgrade my wheels. But ehen i do they will have blue rings. I even have a blue servi arm on the way. My new brushless system should be in soon. After that I am getting MIP shafts. You are supposed to be able to run knuckle weights with the LCC conversion. I am hoping they work with the VP wheels. This should be a solid truck for next years comp season. Wes |
10-07-2011, 12:42 PM | #43 |
Got the 18.5T Mongoose crawler system installed. So far it seems to work pretty well. Looking for some feedback for pinion spur combos people are running. I have the stock spur and stock pinion that came with the system. I am running a 65c 2s lipo. It seems fast enough, but haven't gotten it on the rocks as of yet. Wes |
10-09-2011, 09:35 PM | #44 |
I was able to get in some testing today. The new Mongoose system works like a charm. It doesn't have quite the hill hold a brush set up would, but I think I will get used to it. The good news is I got 19 minutes run time on a 325mah 65c lipo. Need to turn down the brake a tad, it was a little too much if I paused going downhill. With a 2.4 lb rig, it doesn't take much to flip the rig over. Finally twisted my stock driveshaft though. A set if MIP shafts are on order to take care of the problem. the new lighter springs really helped out a bunch. All in all, super impressed with the little guy. Wes |
10-16-2011, 04:16 PM | #45 |
Had my third comp run with the Smurf. This time I actually finished, since my motor didn't take a dump! Very much happy with the Mongoose. I also figured out the rig is just too light. I need about 2 oz in the rear and 4 oz in the front. If I had the money some VP aluminum rims would help me out a bit. I also need to get a shorter servo horn. A few tweaks over the winter and I will be good for next season. Wes |
