09-09-2011, 05:59 AM | #1 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Jeepsohigh's first Mini rockcrawler "little sanchez fawker" After driving 2.2 pro for the last 2 years I have decided to try competing with the 1.9. WOW it sure is different than MOA Here is a "built" thread since its already got it together. I bought a couple of used MRC's on here and then tore them both down and built this one. Specs:
I am still going to have to tune on it. I will probibly go to some high clearence links in the rear. Im going to do the underdrive/overdrive mods to the axles and I might mess around with springs and shock oil but for now I will try and drive it the way it is. Im going to compete with it at crawlapalooza in a month so I need to get some drive time under my belt. Last edited by jeepsohigh; 11-17-2011 at 08:53 PM. |
09-09-2011, 07:04 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
that setup is very close to mimicking the 1.9 I got from bmuzz. you will like the GC3, till you go bodiless/delrin. My only hang up was the rollover capability ( or lack of) with a truck body, and small clearance issues on tight courses. looks like its gonna be dangerous! keep us posted.. |
09-10-2011, 02:54 AM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Looking good |
09-10-2011, 12:59 PM | #4 | |
I do have a proto bodyless chassis to do some testing on so soon so I will be building another MRC. Thanks Last edited by jeepsohigh; 09-20-2011 at 04:30 PM. | |
09-20-2011, 04:30 PM | #5 |
Note to self, do not drive the mini as hard as you do the berg Anyone make "super 300" CVD's for these? Last edited by jeepsohigh; 10-14-2011 at 08:29 PM. |
09-20-2011, 06:13 PM | #6 |
RCC Addict Join Date: May 2006 Location: enid
Throw ya some comp crawler cvd s in that dude......
09-20-2011, 09:00 PM | #7 |
| Huh, Thanks Chad Shows what a 1.9 newbe I am, After your post I did lots of searching and found out a few things
09-20-2011, 09:05 PM | #8 |
I'm running the lcc shafts in mine and sometimes on 3s no problems as of yet....lol
09-20-2011, 10:12 PM | #9 |
I've only broken one side and then I was told that they were redesigned. I'm not sure which is which, but I have a single mrc cvd that looks way different than my others. It also has way less throw than the ones from my other pair. I have had great luck with the newer ones. There's no way in hell you can push this truck like your berg! and you might want to carry and extra ring&pinion or 3. |
09-22-2011, 10:50 AM | #10 |
09-22-2011, 11:05 AM | #11 |
| I'll rephrase. If you run a tight mesh (I throw a couple of shims in under the pinion gear) then you won't go through so many gears. The pinions wear quicker than the rings, so every other time that I change the pinion I change the ring. You will hear a loud click (the same click that's common with a stock xr10) but you won't shear gears.. they will just skip and eat away at each other. You can finish out the day as long as you don't hammer down too much. Trying to throttle out of a bind and verticals where you have to hop and give serious throttle seem to hurt the most.
09-22-2011, 04:54 PM | #12 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
Adding longer bolts on the axle with 2mm nuts has greatly improved the lifetime of my R+P gears. Actually dont think ive had to replace any since the shim mod Nice parts list, should perform well! |
09-25-2011, 03:12 PM | #13 | ||
I had my first comp with this truck today and it just straight performed. I took first place I picked up some alluminum transmission gears and a alluminum spur gear to put in this week and I think I might try the underdrive mod as well. Stay tuned | ||
09-28-2011, 05:36 AM | #14 |
Rock Stacker Join Date: Sep 2010 Location: Saint Louis
Great build Brian. I think you have built an outstanding second place worthy 1.9 My 1.9 should be up soon (But I won't have all the fancy stuff like you ) |
09-28-2011, 05:46 AM | #15 | |
Thanks Ed Second place?, I think you give me too much credit. Louis is gonna kick both our asses. So I will just be third behind you. | |
10-14-2011, 08:44 PM | #16 |
| Well, I did a little more work to the old mini.
It not too much but its an update I Did Comp it at Crawlapalooza and got my arse kicked. Its alright tho, I learned allot for the next big comp. Here are a few pics of my 8th place drivings I picked up a BWD motor plate in OK from Don but I have yet to install it. Last edited by jeepsohigh; 10-15-2011 at 06:43 AM. |
11-13-2011, 10:44 PM | #17 |
| Well with the Turkey crawl in a week I decided to get off my butt and get some more things done on the Mini First I thing I did was the caster mod. This is very easy for sure. Take off c hub, grind some new flat spots about where the mounting screw should be, drill a small pilot hole for the mounting screws, install screws. Heck my steering links even worked fine, I just moved the tirod to the bottom on the knuckle arm. Make sure the hubs are the same angle on both side before you button it up. I also got the BWD motor plate that I bought at Crawlapalooza installed. This is a very nice addition to the heap. Next I put on some NOVA 4" Rovers tires and foams on (thanks Ashton for the deal) These things are nice, and should help with the ground clearance for sure I also installed some Jun fac wheel wideners to make use of all that caster.(thanks Ashton again) Also installed a Robotronics Servo arm. Last but not least I went 3 cell on the lipo's I think she is as ready as she is going to be and I cant wait to run it in Alabama. |
11-14-2011, 07:47 AM | #18 |
3s Looking good man |
11-14-2011, 12:41 PM | #19 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Quick question. What did you do with the shrink wrap to those junfac wideners. I also notice you had then with the pins outside. What mod have you done to do that?
11-14-2011, 01:00 PM | #20 |
| They are flipped around, trimmed, a new slot is cut for the pin and the shrink wrap is there to make sure that the pin doesn't fly out if things loosen up.
