09-18-2011, 09:09 PM | #1 |
Rock Stacker Join Date: Jun 2005 Location: Philadelphia
| New MRC Pro - Need servo advice
Hey all...I know this has been asked before (in this thread - Which Servo would you pick? - to be exact), but didn't find my answer there.. I'm new to the whole 'comp crawler' realm, and wanna build my MRC as a comp crawler (1.9 most likely), and looking for a decent servo - using the stock mounting setup. So I guess I'm looking for the best micro/mini servo thanks!! |
09-18-2011, 09:18 PM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
you can use a standard servo on it, hi-tec 645 works good for the price
09-18-2011, 09:38 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
x2 on the 645. I've got a few mrc all with them and they have been working fine.
09-18-2011, 09:44 PM | #4 |
nothing wrong with a 645 I have also used stock rtr servo's off axial kits with great success. |
09-18-2011, 09:44 PM | #5 |
Thanks...I was wondering what most guys are using I'm considering this route (now that I've got an idea of the size) - http://www.amainhobbies.com/product_...tal-Gear-Servo - Savox SC0252MG... a couple bucks more then the Hitech, but I've been having a lot of luck with the savox servos in my TCs anyone else try one of these? |
09-18-2011, 09:46 PM | #6 | |
that would work IF I had an RTR servo sitting around...I think I gotta see what kind of Hitec's I got sitting around...I think I got some hitec digital over powering 8th scale buggy servo sitting around - might actually be cheap and go that route | |
09-19-2011, 12:16 PM | #7 |
Rock Crawler Join Date: May 2011 Location: SoCal
I'm making the same decision for a new MRC Pro. The width between the servo mounts is 36.5mm. The servos you guys are looking at have case widths in the 40-41mm range. I know there are aftermarket plates to allow larger servos, but then I assume you lose the RF axle-top as an option for the battery? Or can you fit a full size servo on the axle and still fit a battery next to it? I'm not anxious to find another place for the battery. This thing ain't exactly roomy inside. |
09-19-2011, 12:33 PM | #8 | |
I went with a slightly different route. The upper links are attached to the servo plate so you have to consider that. My fix was to get a second servo plate set and cut the lip off the rear one to use as the upper link attachment, then I bought a full size alloy servo mount and sandwiched the rear mount between the alloy plate and the axle. I used Axial servo mounts to attach the servo. I always place the battery on the upper links in front. So I use either a 2S or 3S 800mah pack velcroed to a lexan piece wire tied to the links. I installed the ESC on another lexan piece over the rear upper links. Last edited by AreCee; 09-19-2011 at 12:38 PM. | |
09-19-2011, 12:53 PM | #9 |
Thanks AreCee. I can see how that would all work. But plan A is to keep battery and servo on the axle. I realize you can move the center post, but then you loose battery space. This servo is a little pricey, but smaller than the big boys: SPMSA6030 Then I want to see if the Thunder Power G6 325mah will fit next to it. It's gonna be close. From the pic's, it looked like Rubbaneck was using that servo with the Losi cube lipo on his championship winning rig. Edit -- found I could fit both the Losi cube lipo and the full size servo on the axle. Just barely. Unfortunately the cube lipo is discontinued so I only have the one. Haven't found anything else that will fit on the axle with a big servo. Last edited by WAM; 10-10-2011 at 09:39 AM. |
