09-27-2011, 10:28 PM | #1 |
Rock Crawler Join Date: May 2011 Location: SoCal
| FXR settings?
Recommended FXR settings via Hotwire? I actually found some, but the thread author had deleted the images, so no actual info remained. Motor = CrawlerMafia 17 on 2S/325mah/65C Bat. Here's where I started: (from memory, undoubtedly forgot some) Updated to V30 Dragbrake = 75 (should it be 100?) Brake force = 100 Reverse force = 100 Neutral = 33 for narrower dead zone (should it be even less?) Throttle profile = 1 for minimum low throttle action Brake profile = 1 for minimum early brake action Braking mode set to fwd & instant reverse Lipo cutoff set to 2 (for 2S battery?) But don't anyone copy me. I don't yet know what I'm doing, hence this request for experienced help. I'm looking more for smooth control versus lightning reactions. Thanks |
09-28-2011, 12:16 AM | #2 |
Pebble Pounder Join Date: May 2008 Location: Two Harbors, MN
I would recommend a drag brake of 100% Neutral width is fine at 33. Its basically the dead band between forward and reverse/brake. cutoff of 2 is absolutely right for a 2s pack. You could also set a custom cutoff if desired. Just remember it's pack voltage not per cell. 6v = 2s. Your also right if you like a smooth start up. Profile one is the most throttle curve. 3 would be linear. I also set the brake profile of 1. It will also effect the input of reverse. Same thing 1 is the most curve. 3 is linear. Just remember 1 has more of a delay. 3 is linear. 5 is almost instant. Hope this helps. |
09-28-2011, 08:24 AM | #3 |
Thanks. I think I'll have to play with the throttle profile. I want smooth, but building in a delay doesn't seem a good thing.
09-28-2011, 08:27 AM | #4 |
Actually id try it. Its not as bad as you'd think. I will run profile 1 on my MRC. Im building it now. I do run profile one on my XR-10 with twin FXR's with brood 35t on 3s. I love it. Very smooth.
09-28-2011, 08:41 AM | #5 |
Throttle profile is same as expo, right? And my 4PL radio also has expo. I wonder if I should use one, the other, or expo-squared?
09-28-2011, 10:26 AM | #6 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
since you are useing a 4pl radio i would post on this 4PK Setups, Tips, Tricks and Help and ask Harley as he is very helpful with any ?? that have to do with futaba radios.... |
09-28-2011, 11:07 AM | #7 |
| Your absolutely right. Expo is the same. The esc is just setting a Throttle curve. I tend to use the esc curve over my radio but that's just user preference.
09-28-2011, 11:08 AM | #8 | |
09-28-2011, 11:13 AM | #9 | |
09-28-2011, 12:20 PM | #10 |
| Heh, my situation exactly. Two in an XR and now building an MRC Pro with one. I just last nite got the hotwire riunning, so programmed the new one for the mini and will get to the XR shortly. Did you do anything different on the XR? I'm guessing people put less dragbrake in the front than the rear for downhill braking stability. Everything else about the same?
09-28-2011, 03:18 PM | #11 | |
09-28-2011, 04:15 PM | #12 |
Here's my current FXR setup in my XR . This will be exactly what I will run with in my MRC. Take note I am running 3s in both. That's why my voltage cutoff is set at 3. I do have my neutral width set higher. This is how sensitive the initial touch of the throttle is. A low # is immediate and a higher # has a slight delay. Its not much but helps. To me the initial throttle seems smoother with I higher #. |
