10-16-2011, 02:52 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: arcadia
| Scrub radius?
Ok first off, I did search and cant find what I am looking for. I have a mrc with gmade wideners on it, can someone explain to me how a widener gives you a huge scrub radius,and why that is such a big deal, is the trade off for stability worth it? I know you all have opinions. Lets hear them. |
10-16-2011, 02:57 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
| Scrub radius - Wikipedia, the free encyclopedia Read up on this and it will give you all the info you need to more understand scrub radius. |
10-16-2011, 03:12 PM | #3 |
| Well that was a good read,melted my brain. Gonna let it soak in, read it again, hope it makes more sense then. Last edited by diggindeep; 10-16-2011 at 03:14 PM. |
10-16-2011, 03:14 PM | #4 |
10-16-2011, 03:19 PM | #5 |
10-17-2011, 05:16 AM | #6 |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
I ran my mini with wideners at the front only. This is the way i prefer the mini, stable front end, with narrow rear, makes for great turning cicle: if you do the following: Losi CVDs, Zero ackerman steering (redrilled knuckles), clock the front axle back about 20 degrees. Overdrive the front axle (traxxas +1 tooth pinion). The turning cicle on my mini was tiny (about 24inch compared with about 6foot plus on stock setup!) If I popped the throttle it would turn tighter. The wideners helped me lots, in that the extra width was stable and gave a great grab when attempting ledges (the wide stance "reaches" out and can hook a ledge, then haul the rig up with careful steering). I run a similar wide setup on the XR10. |
10-17-2011, 06:50 AM | #7 |
Thanks for the input. Very helpful,and I do have aluminum chubs,zero Ackerman knuckles and cvd.
