10-17-2011, 03:49 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: New London, PA
| Will theses work even though i am running a 1.9'' tire?
Looking to get theses but says for a 2.2 but will they still work with a 1.9? 2.2" Wheel Widener for Axial AX10, SCX10, Losi 1/10 Crawlers, TLT-1, XC or CC-01 (Pajero, Touareg) #J51032*-*Wheel Wideners, Adapters, Glue (CA) and Miscellaneous Items*-*-Wheel Products*-*The Crawlers Store LLC |
10-17-2011, 03:55 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
yes they will work, aslong as your wheel uses a 12mm hex.
10-17-2011, 03:56 PM | #3 |
i am just running some hpi black stock car rims.
10-17-2011, 04:04 PM | #4 |
10-17-2011, 04:18 PM | #5 | |
| Quote: | |
10-17-2011, 04:27 PM | #6 |
yea just realized that haha. are the ones from rc4wd any better? cuz they have the tires i want for alot cheaper them tcs.
10-17-2011, 04:35 PM | #7 |
They probably arent any batter or worse. If they are the width you need, then they should work just fine.
10-17-2011, 07:27 PM | #8 |
| The RC4WD ones require you use the stock hex's where the others don't. I prefer the least amount of parts so I would go with the Junfac's from TCS but in order to save on shipping I can see why you may not.
10-18-2011, 07:28 AM | #9 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
I run the junfac's, I did drill out axle to use bigger pin and had to drill out rim to fit barrel nut, just to let you know
10-18-2011, 12:00 PM | #10 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
why not give these a try? Traxxas Mini 1/16 Revo Alum Wheel Extension Widener Kit | eBay even though they are listed for a MERV, they look to be built like the junfac units, and are almost $10 less |
10-18-2011, 02:27 PM | #11 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I know a lot of guys have been running the junfac's with the stock pins. This is doable just keep in mind you don't want to over tighten the wheels as they will crimp down on the knuckle bearing and bind up.
