Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Motor Ideas & motor soldering ??'s
Old 10-31-2011, 09:17 AM   #1
Default Motor Ideas & motor soldering ??'s
I got a contraband i'll be running for comps in 2012, Looking for a NICE back-up motor Just in case any suggestions? Also Can I solder wires from motor so I can install some castle bullet connectors for easy motor changing?
My esc is a sidwinder and has the bullet connectors on it already but dont want to run the castle motor that it came with. I went ahead an ordered the cc 4mm male/female bullets.
WestTxRc is offline   Reply With Quote
Old 10-31-2011, 09:43 AM   #2
yes you can i have a hh motor & a micro pro with the setup you are asking about its a little tricky but if you setup a soldering fixture with alligator clips its much easier tin the motor tabs & tin the bullets than put the pieces together
usslandlocked is offline   Reply With Quote
Old 10-31-2011, 09:56 AM   #3
Not sure i can find a Holmes mini torque they seem to ALWAYS be sold out.
Any other suggestions on a Good back up motor to the contraband I going to run? Not expecting problems with the COntraband but you never know.
Money's No object either as long as its good.
Old 10-31-2011, 10:06 AM   #4
ya good luck on the hh motor PM eddieO WITH TEAM BROOD HE IS MAKING SOME WICKED MOTORS FOR THE MRC!
Old 10-31-2011, 10:08 AM   #5
Alright thanks I'll give him a pm.
Old 10-31-2011, 10:22 AM   #6
Actually if all you wnat is a back up motor ou could do a little losi insane motor. Surprisingly gutsy for what they cost. Or get a reedy mini-max. half the cost of you main motor ( understandably so) but adequete for the purpose
sickpuppy1 is offline   Reply With Quote
Old 10-31-2011, 11:52 AM   #7
dnf
rock hard's Avatar
top choice IMO for you would be to ry to put your hands on a
19t-17t reedy mini mod or
22t trinity mini monster
Both share parts with my motors
and both are rebuildable
but really for a backup,nearly any brushed motor will do in a pinch.
rock hard is offline   Reply With Quote
Old 10-31-2011, 07:01 PM   #8
If you want a back up motor and money is no object why not order another contraband motor. Then in the unlikely event of your motor failing you will be replacing it with something just as good
Sure Rock Hard would be happy with that solution though too modest to suggest it himself.
Torque Masters are always out of stick because HH no longer makes them.
neiloid1 is offline   Reply With Quote
Old 11-02-2011, 07:03 AM   #9
Didnt know RockHard had any more motors left. If you do shoot me a PM.
