11-04-2011, 10:58 AM | #1 |
Newbie Join Date: Oct 2011 Location: Portland
| MRC Pro Mods
What mods/tweaks should be done to the MRC Pro right out of the box? From what I've seen, flipping the tranny is a must and perhaps flipping the shocks upside down. Anything else?
11-04-2011, 11:55 AM | #2 |
I wouldnt bother with flipping the shocks. heres what ive done- cheap/ free mods- batery on front upper links rx on rear upper links weight tires/ wheels bought mods- MIP drive shafts (stock break easy) bent lower links (rear) aluminum C-hubs doesnt need much to be a very capable rig. |
11-04-2011, 12:32 PM | #3 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
11-04-2011, 12:35 PM | #4 | |
I also made a centered servo mount using the existing upper link mounts to eliminate the wheel rubbing the servo. Lastly I have Rovers with I-nova foams. Flip the trans? Wouldn't hurt much. Mine works nicely the way it is. | |
11-04-2011, 01:29 PM | #5 | |
| Quote: | |
11-04-2011, 02:38 PM | #6 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
if your not comping just add weight to the tires and go play tell something breaks. I liked when i changed out the one hole valve for the three hole ones in the shocks leave driver rear with one hole though
11-05-2011, 12:36 AM | #7 | |
11-05-2011, 12:50 AM | #8 |
It showed up today and I am very impressed. I immediately removed the stock driveshafts to put on the MIPs I already had purchased. One of the set screws stripped almost immediately even after heating with a soldering iron. I ended up having to drill it out which worked out well since I was tossing the stock ones anyway. My only real complaint so far has been the screws. They are so tiny that I feel like I'm going to strip almost all of them. The largest ones I have seen are the ones holding on the servo. Other than that, great little rig. I'm going to fashion a tray for the electronics and battery (still using stock MRC electronics). Thanks for the suggestions, guys. I'll start doing those little mods as I feel the need for better performance. |
11-05-2011, 07:33 AM | #9 |
Outboard the shocks at the axles. The stock setup is wayyyyy too flexy.
11-05-2011, 08:12 AM | #10 |
11-05-2011, 09:55 AM | #11 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
Just follow Rubbaneck's setup to start out and you too can win a national championship! |
11-05-2011, 11:29 PM | #12 | |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
He is WARCRC 2010-2011 1.9 series champion. Not national champ. I would start out with good electronics and servo first and definitly get the 1.9 rovers. Then add weight on the front. From there you can tweak it to your liking. | |
11-10-2011, 01:34 PM | #13 |
Newbie Join Date: Oct 2011 Location: everett
Is weight in the tire or on the rim a better choice? Thanks |
11-10-2011, 01:47 PM | #14 | ||
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
Rubba's MRC PRO Half-Pint | ||
11-10-2011, 03:55 PM | #15 |
Quarry Creeper Join Date: Nov 2010 Location: Atlantic
| HE LIVES!!
