03-31-2012, 06:30 PM | #161 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Re: Papabash's Team BWD 'Low-Pro' Wedge Build |
03-31-2012, 09:58 PM | #162 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
So I bit the bullet and got mine . I got a white one from Britt. I'm now subscribed to this thread and might be asking you a few (ok it might be a lot ) anyway. Yours is awesome |
03-31-2012, 10:34 PM | #163 |
BTW were is a link to the DLux LCC mod?
03-31-2012, 10:47 PM | #164 |
03-31-2012, 10:48 PM | #165 |
| Re: Papabash's Team BWD 'Low-Pro' Wedge Build Start here, I think around page 4: Harley's GC3 Mini Build Then go to D-lux's site and look at the pictures of his adapter pieces. Those 2 things are what I went by when I did mine. |
04-02-2012, 10:18 AM | #166 |
I just went through this whole thread and saved 47 pics to my computer . I'll then have them for easy access to refer to them. I hope you don't mind. What's the part # for the axial bent rod ends? Last edited by EverettY; 04-02-2012 at 10:31 AM. |
04-02-2012, 03:08 PM | #167 |
LOL, nope, I don't mind at all. They are here to help others, I'm glad to see them be used. I don't know about the Axial bent rod ends, I just had some lying around from old builds. They come on a parts tree, I don't think they can be bought separately, but I sure wish they could. Maybe someone else has the part # for the tree? |
04-02-2012, 03:14 PM | #168 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Papabash's Team BWD 'Low-Pro' Wedge Build Quote:
J.D. | |
04-02-2012, 03:23 PM | #169 |
Just got home and grabbed an SCX-10 manual; the tree is part number AX80005.
04-02-2012, 03:27 PM | #170 |
Thanks! found it but it's $6.50 and it only has 2 of the rod ends :(
04-02-2012, 04:58 PM | #171 |
True, that's why I wish you could buy them separately, but are you really going to let $6.50 stop you from making an $80 chassis perform to it's full potential?
04-02-2012, 06:33 PM | #172 |
How many of them are you using? It looks like 4 as far as I can tell
04-02-2012, 06:39 PM | #173 |
Four is correct.
04-03-2012, 02:38 PM | #174 |
What hardware do I use for the LCC conversion? BTW you weren't being rude at all I totally understand.... |
04-03-2012, 02:54 PM | #175 |
The rear-steer kit comes with most everything you need. I used some longer M3 screws to attach my tie rod/drag link, but your particular steering setup may not need them.
04-03-2012, 03:07 PM | #176 |
Ok so do you have the ones that came with it that you would be able to sell me? Since you said that you used the M3 screws.
04-03-2012, 03:57 PM | #177 |
They were 4-40 or some weird thread pitch, so I threw them in my "odds and ends" box of screws, nuts, bolts, etc. Since I've been in and out of RC for about 30 years, it is pretty much a black hole for misfit hardware - don't really wanna go there, sorry.
04-03-2012, 06:01 PM | #178 |
Ahh NP Could you tell me the screw I need to get?
04-03-2012, 06:39 PM | #179 |
I could, but it might be totally wrong. You need to work out your linkage first, and then see what it takes to accomplish it. My best advice is to go to your local Ace Hardware (or whatever franchise you have nearby) and get some M3 machine screws in assorted lengths. I like to keep them on hand up to around 30mm with a few 40 or 50mm ones that can be cut off as needed.
04-03-2012, 07:09 PM | #180 |
Ok So in those pics I sent you was that all I needed?
