12-24-2011, 11:10 AM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Lufkin
| What component causes this?
I'm having trouble maintaining a consistent speed. As soon as the rig is free from obstacle it greatly speeds up. Is this because the motor is weak and can't push it's way through the obstacle? I know it seems obvious that when it's no longer under load that it would speed up but the difference is pretty extreme. I'm running all stock electronics for now. I've got a br-1, rims, tires and various other parts under the tree. I've not seen any reason to upgrade the motor until I noticed this issue, if it is even an issue. Just makes it harder to maintain a specific, controllable and predictable speed. |
12-24-2011, 11:42 AM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: Atlantic
| Re: What component causes this?
Stock motor.....yeah , it will do that. I ran a stock motor in my pro for a while, then I got a Brood motor......night and day difference.
12-24-2011, 12:27 PM | #3 |
| Re: What component causes this? |
12-24-2011, 12:49 PM | #4 |
Yup.....Team Brood motors in the vendor section.
12-24-2011, 01:01 PM | #5 |
Well guess I need to do some research, I'm so motor tarded I have no idea what size the stocker is? And I don't want to bore ya'll with the over asked questions. edit: Is the brood anarchy 19t the motor of choice? I'm not much of a speed demon. Back in my 2.2 days I'll I ever ran was the 55t and 60t lathe motors. Is 19t torquey enough? Just seems small to me, but I'm new to the mini world. Last edited by Rooney7783; 12-24-2011 at 01:07 PM. |
12-24-2011, 01:28 PM | #6 |
I run the 18t anarchy in mine and it has plenty of torque.
12-24-2011, 03:46 PM | #7 |
Are the anarchys bolt in? Will the stock pinion gear fit it?
12-25-2011, 09:40 PM | #8 |
12-27-2011, 11:08 AM | #9 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
12-27-2011, 11:50 AM | #10 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Before you potentially ruin some nice new stuff let me suggest some things. Pull the motor and drive shafts and make sure your tranny is spinning freely and do the same for your axles. Case and point. My rig was doing the same the other day, and it turns out I was doing some poor refitment on some stuff and my knuckle weights had slid into my inner beadlock ring. Your better off with the parts regardless but just check everything first. RickM |
12-27-2011, 09:25 PM | #11 |
12-28-2011, 06:35 AM | #12 |
I never got enough drag out of the novak. It went with my GC3 chassis.
What component causes this? - Similar Threads | ||||
AX-10 Component help | SamuraiTrapper | Axial AX-10 Scorpion | 6 | 10-19-2009 05:02 PM |
component spacing? | Devinb | Newbie General | 2 | 01-26-2009 05:39 PM |
Component list question | BlueMonster | Electronics | 0 | 03-12-2008 08:19 AM |
Axle component list | PaulEZK | Traxxas Crawlers | 9 | 10-26-2006 09:02 AM |
