01-26-2014, 06:51 PM | #221 | |
Rock Stacker Join Date: Feb 2012 Location: Modesto
| Re: Ittybitty's MRC "Built" Thread Quote:
Thanks -steve | |
03-07-2014, 08:12 PM | #222 |
Newbie Join Date: Oct 2012 Location: SATX
Hey guys, I'm kind of new at this.. I'm thinking about getting the modified 380x but I have a couple of questions first.. Is this direct fit or does there need to be some modifications to go into the stock losi mrc? Also, what spur and pinion setup should I go with? Do I need to get the spur or can I just get a pinion? I am strictly just crawling for fun but I want a capable crawler as well.. I've read through this thread a couple of times and cant figure this out.. Thanks in advance for all of your help! Last edited by mike253905; 03-07-2014 at 08:24 PM. |
03-08-2014, 04:45 PM | #223 |
Quarry Creeper Join Date: Aug 2013 Location: Canada
Well the 380X being a bigger motor, you can't set it very close to the spur (hits the transmission case) so you're gonna need a bigger spur to reach your small pinion, or use a bigger pinion (maybe too much speed). Apart from that it's supposed to screw right in, except it may hit your chassis because of the size, depending on how you are setup. |
03-08-2014, 08:39 PM | #224 |
I see. Thanks for your help bro and clarification.
03-10-2014, 05:23 PM | #225 |
hows it going any updates on this build?
03-10-2014, 05:38 PM | #226 |
RCC Addict Join Date: Nov 2007 Location: somewhere
Sold it
03-10-2014, 05:59 PM | #227 |
The new owner continued with the thread tho..
10-16-2014, 02:40 PM | #228 |
Rock Stacker Join Date: Jun 2009 Location: Idaho Falls
| Re: Ittybitty's MRC "Built" Thread |
10-18-2014, 09:26 AM | #229 |
jerrys800 is the new owner of this car!
Ittybitty's MRC "Built" Thread - Similar Threads | ||||
~" Rc4wd's RCX TIMBERWOLF "~ Built by Run2jeepn | run2jeepn | 2.2 Scale Rigs | 118 | 02-23-2011 06:38 PM |
MRC "motor noise" and L-trail chassis "drive shaft" | joeel | Losi Mini-Rock Crawler | 6 | 03-04-2010 04:38 PM |
