01-08-2012, 08:58 PM | #21 |
RCC Addict Join Date: Nov 2007 Location: somewhere
| Re: Ittybitty's MRC "Built" Thread |
01-12-2012, 11:54 AM | #22 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
Sweet looking mini |
01-12-2012, 04:47 PM | #23 |
| Re: Ittybitty's MRC "Built" Thread Thanks Jim! It's working great too. I was lucky enough to have a buddy cut some rear axle weights prior to our last comp and will be working with them this week in order to reduce their weight and provide the ability to adjust weight as needed. Right now they weigh 2.2oz per side which is too much for a permanent set up...although the rig sticks to sidehills with that much weight on it! I'll post up some pics of these after a few changes are made. |
01-12-2012, 04:54 PM | #24 |
I was cleaning all of my tires from this weekends rainy comp and figured I'd have some fun and run the 2.2 tires and wheels on the MRC...BAM 1.9 Super Class! http://youtu.be/s_Ug4QpQIFE?hd=1 Last edited by ittybitty; 01-12-2012 at 05:01 PM. |
01-12-2012, 04:58 PM | #25 |
Rock Crawler Join Date: Jun 2010 Location: SENECA
Well roll overs would be easier.
01-13-2012, 02:09 AM | #26 |
Rock Crawler Join Date: Dec 2010 Location: Piedmont, SC
Looks like a mini tyco rebound! |
01-13-2012, 03:21 AM | #27 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
Haha I tried my 2.2 rovers on my mini. It performed suprizingly well although the centre of gravity went why up. A tyre inbetween would be sweet. Nik |
01-13-2012, 08:19 AM | #28 |
U don't get much steering with the 2.2 tires on them. They do crawl better in a straight line. Ryan did u take it outside on the rock pile |
01-17-2012, 12:37 PM | #29 |
Here's what I've been working on lately. A friend of mine made these rear weight slugs which fit really well and accomplish the task nicely, but at 2.2oz they just weigh too much for a permanent solution. I set out to reduce them to 1oz or less and to get the weight as far out on the axle as possible AND to be able to add weight as necessary. Here's my progress: Here they are at their new 1oz weight...and with a little more to lose after drilling some holes and such... Comparison of how they looked at 2.2oz... With the tire/wheel mounted they don't hang out at all now... This is how they looked when mounted as I received them... |
01-17-2012, 01:52 PM | #30 |
Ryan I believe Im gonna need a test set of those How about being able to bolt on more weight kinda like VP knuckle weights, but having the weight low???
01-17-2012, 05:02 PM | #31 |
01-17-2012, 05:10 PM | #32 |
Quarry Creeper Join Date: Sep 2009 Location: Granite City (Mt. Airy)
Those are looking good Ryan. I've been thinking about something similar. Is there a reason why you have them rotated towards the rear? I see you've been doing some BEC mods; I noticed the little rectangle piece in the pics. |
01-17-2012, 08:34 PM | #33 | |
| Re: Ittybitty's MRC "Built" Thread Quote:
Right now the weights are just kinda thrown on there...not necessarily in the position they'll be run in. I'll most likely run them straight up and down when installed. I plan to spend a little time in the shop tomorrow and get the weight for the other side trimmed down. The tools I have to work with don't make it incredibly easy, but a little patience goes a long way! If I don't run out of daylight I'll go ahead and drill and tap them for the extra weights. I might even drill some extra holes in the holders in order to reduce their weight even more. I think they could handle few extra holes above the axle center line | |
01-17-2012, 10:45 PM | #34 | |
I figured you wasn't going to running the weights in that position. I'm going to try to get started on some for mine tomorrow and I don't even have any fronts weights yet. Last edited by Gear Jammer; 01-17-2012 at 10:46 PM. Reason: Change text | |
01-20-2012, 12:44 AM | #35 |
Well I got side tracked because the 4 link mount I picked up from Robotboy showed up so that opened up some new possibilities with my steering setup. I was able to center the servo...but chose to offset it to the passenger side just a touch thinking that if I was going to keep weight up there it might as well be off on the side that needs it more than the other due to torque twist. I was also able to add a bit more caster and then went to work on the knuckles, chubs, and weights to provide as much steering as possible. I think I could squeak out just a hair more, but I'm pretty sure what I've got now is about as much as I'll be able to use effectively. Check it out... |
01-20-2012, 01:02 AM | #36 |
Looks good Ryan... I figured you'd have that mount on there quick. |
01-20-2012, 06:01 AM | #37 |
RCC Addict Join Date: May 2009 Location: In the warmth!
Looks real good Ryan, glad I could help ya out like you need it... Anywho, Diggin the weights, nice job |
01-20-2012, 09:39 AM | #38 | |
01-29-2012, 06:53 PM | #39 |
Newbie Join Date: Jan 2012 Location: southeast
Great thread Ryan! I just bought the Losi Mini from you this weekend so this is a big help! |
01-29-2012, 07:08 PM | #40 |
Hope it doesn't put too large of a hole in your wallet though! I just wish we carried more parts for these little guys!
Ittybitty's MRC "Built" Thread - Similar Threads | ||||
~" Rc4wd's RCX TIMBERWOLF "~ Built by Run2jeepn | run2jeepn | 2.2 Scale Rigs | 118 | 02-23-2011 06:38 PM |
MRC "motor noise" and L-trail chassis "drive shaft" | joeel | Losi Mini-Rock Crawler | 6 | 03-04-2010 04:38 PM |
