12-09-2011, 08:55 AM | #1 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
| DIRECT fit brushed motor for Pro?
Can anyone tell me a brushed motor that is a no-mod fit for the MRC Pro motor plate? Thanx! |
12-09-2011, 09:11 AM | #2 |
The losi mini crawler motor...sportwerks motors, reedy stump puller, misc. reedy mini mod motors, and a few more, but im not sure if they require work to the motor like the losi slider motor that needs the shaft sanded/ground down with a dremel to accept a mini-t pinion.
12-09-2011, 09:14 AM | #3 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Losi part no. LOSB1216. It's the RX-280 Mini Slider motor, has great speed, torque, and drag brake, all for around $17 shipped. I put one in my daughter's rig, and it works great; it's a bit noisy for a bearinged motor, and drains the batteries faster, but for the price it's darn good IMO. I don't know if the noise and lower run times are normal for this motor or not, I have another one I am going to put in when I have time and see if it's better.
12-09-2011, 09:15 AM | #4 | |
12-09-2011, 09:19 AM | #5 |
Rock Stacker Join Date: Dec 2009 Location: Gardner
I'll second that on the mini slider motor. Have been in a few comps locally with it and have not found anything yet it couldn't handle.Yes, the Broods, Anarchy, Holmes ,and reedy motors are more powerful and faster. But for the buck, it really is hard to beat! mine was geared with stock spur and a 10 pinion. When I went to a 62 spur, its gutsy-er yet! And I'm on 2s too.
12-09-2011, 09:22 AM | #6 |
I drilled out the pinion to the next size larger bit and it went on with very little hand force. That way I kept the grooves on the shaft for holding power. LOL, I blew all the teeth in my tranny, but my pinion never slipped........
12-09-2011, 09:23 AM | #7 | |
12-09-2011, 09:43 AM | #8 |
Rock Stacker Join Date: Jan 2008 Location: Southern IL
So i guess wiring the slider motor up and then using some sandpaper or a file while its running will work? A.D. |
12-09-2011, 09:54 AM | #9 |
| I would say it was a little noisy, but no noisier than the Insane that's in there now. I run 725mah packs, so I would run all 3 courses with the same pack. And then play a little afterwards before it ran to the LVC. I think especially with the 62 spur it took a load off the motor in normal comp conditions which lowers current draw, but even before I did that I was completing all 3 courses, so...?
12-09-2011, 10:00 AM | #10 |
| I guess you could, but thats one of the reasons I decided to drill out the gear instead of the shaft. The spinning motor has a tendency to pull in air for cooling. Which means metal filings and sand will tend to get pulled into the motor when running. No thanks. Granted, dirt can get sucked in too when running normally. still, not as abrasive and metal and sand.....Thats just how my head works, right or wrong,lol
12-09-2011, 10:31 AM | #11 |
Thanx guys! That helped alot.. I had heard/read that 370/380 motors did not fit the Pro motor plate screw pattern... Last edited by the_ghetto_rig; 12-09-2011 at 10:38 AM. |
12-09-2011, 12:43 PM | #12 |
hmmmmm is there a better way to remove them? like... temporarily cover the inlets and run it in very very very (did i mention very?) short bursts? A.D. |
01-14-2012, 01:41 AM | #13 |
Rock Stacker Join Date: Jan 2011 Location: Germania
| Re: DIRECT fit brushed motor for Pro?
Hey i just killed my Mini Torquemaster and am now searching for a cheap but good alternative. I was thinking about: the LOSB 0839 MRC original motor, the LOSB 1216 RX-280 Mini Slider motor, the LOSB 1218 Mini Sprint or the LOSB 0837 Insane 370 motor. I want a good brake enough torque low speed and highspeed too. I want to drive this setting with the Tekin FX-R and 2S or 3S. What are the pros and the cons for these? Has anyone some experience? Or are there other cheap possibilities I didnīt found yet? Thx so far Last edited by WeekendWarrior; 01-14-2012 at 01:50 AM. |
01-14-2012, 03:46 AM | #14 |
Rock Stacker Join Date: Mar 2011 Location: The Netherlands
The losi insane 370 fits as a bolt on. Great motor with lost of wheelspeed and torque. The dragbrake is also really good. The losi insane fits fine on the stock motorplate but you need to flip the pinion around. (put on backwards) I like my sidewinder micro and insane 370 combo very much. On 3s this combo will shred axles and gears so be carefull. Last edited by martoediefroets; 01-14-2012 at 03:52 AM. |
01-14-2012, 08:58 AM | #15 |
Yup..I went with the losi insane...and love it...
01-14-2012, 09:32 AM | #16 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
If you purchase the Mini-T big block motor plate, then 370 motors bolt right up. That being said, I am having very good performance with a Promax Cobalt 370 motor. These can be had for $20 . Promax Cobalt Motors I like the 3745 unit, and am running that on 3s. I ALSO HAVE THE 3726 in case I want to switch and run 2s. The big block motor plate can be found here: FULLFORCE RC - LOSI Mini-T PARTS. Rock solid American made products for your Team Losi mini-T or Baja truck. I also just picked up a small Hyperion brushless in runner 370 size to try thru all eRC. ALL e RC | HYPERION Y-22 SHORT MOTOR 2850 KV None of these motors require shaft grinding or pinion drilling...and they all are available at a fair cost. |
01-15-2012, 09:14 AM | #17 |
@martoediefroets Is it possible to crawl real slow the insane? Which gearing should be used on 2S / 3S? Is it as big as the Torquemaster? Size matters in the MRC, right Last edited by WeekendWarrior; 01-15-2012 at 09:24 AM. |
01-15-2012, 10:04 AM | #18 |
| Re: DIRECT fit brushed motor for Pro? Here's a vid if my MRC on the Insane with 10/62 gearing and 2S lipo..I have heard a number of times that 3S on the Insane is NOT recommended for the stock drivetrain, you would need HR gears for your tranny... Indoor 1.9 obstacles... - YouTube |
01-15-2012, 10:27 AM | #19 |
Looks good but wherefrom did you get the 62T spur gear? Do you have a part no.? Which pinion gears do fit? Do you have a part no. for the 10T too ? Last edited by WeekendWarrior; 01-15-2012 at 12:02 PM. |
01-15-2012, 10:32 AM | #20 |
Hot racing 62T: Buy Losi Mini Rock Crawler, Aluminum 62T Spur Gear Hard Ano MRC862H N/A, from Hot Racing for $9.48 now at ToadzRC.com. Associated RC18T pinions: ASC21152 Associated RC18T 10T Pinion Gear |
