| | #1 |
| Rock Crawler Join Date: Feb 2010 Location: eugene
| I have a MRC Pro, and I want to put some metal drive lines on. As ive twisted and broken the stock ones. I was wondering if anyone has installed a set of the integy, mip or 3 racing drive shafts with out having to shorten them. I had to shorten the drive shafts on my creeper, when i switched from the stock chassis with a ax10 tranny to the vp insision chassis. |
| Sponsored Links | |
| | #2 |
| Rockin' with SMRCRC ![]() Join Date: Mar 2009 Location: In The Dog House
| Go with the MIP's. They fit directly, no modifications needed, and are super tough. Just make sure you use red Loctite on the grub screws and tighten them down good or the pins will work out. |
| | #3 |
| Rock Crawler ![]() Join Date: Oct 2010 Location: NW Washington
| I have MIP drivelines on both my minis. They work great. The setscrews strip easily so watch that. |
| | #4 |
| RCC Addict ![]() Join Date: Aug 2007 Location: Marshalltown
| I agree with Ted, go with the MIP's. Immediately when you pick them up at your Local hobby shop, match the grub screw size with the other ones they have. Most of the time they will have a larger opening for a bigger allen key. |
| | #5 |
| thanks guys for the replies! |
| | #6 |
| Newbie Join Date: Mar 2012 Location: hattiesburg
| i had a set of integy and they broke wit in like 2 min my stock ones were stronger than them i think i am going with the MIP's everyone seems to have good luck |
| | #7 |
| Quarry Creeper Join Date: Jul 2011 Location: Hemet
| the integys are cheap pot metal...mking them very weak...mip is the way to go...i can have my crawler in a bind(with a mongoose bl system) runnng off 3s, punch it, and theyll never break...mip is the way to go for sue |
Drive shaft question - Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| drive shaft question? | TRAV | Kyosho Twin/Mad force | 3 | 01-06-2010 03:24 PM |
| Punisher drive shaft Question | curve | HPI Wheely King | 3 | 01-01-2008 01:42 PM |
| Drive Shaft Question.. | HAWAIIROCKBUSTER | Newbie General | 2 | 05-07-2007 11:37 AM |
| drive shaft question | tltcrawlerxtrem | Tamiya TLT Crawlers | 4 | 01-17-2007 09:43 AM |
| VMG Drive Shaft Question | SupermanWV | General Crawlers | 10 | 03-08-2006 05:23 PM |
| Thread Tools | |
| Display Modes | |
