01-22-2012, 01:34 AM | #1 |
Newbie Join Date: Jun 2011 Location: West Coast
| Tech questions-- Slipper clutch, shocks, tire foams..
First of a few questions I have is, do the MRC Pros have slipper clutches built in? I have a stock motor and find that in a bind the motor will stop. Is this normal or do I need to set the slipper (if there is one)? Second question is when you outboard the shocks, is it usually on the top or the bottom? I've read where guys have done one or the other but still unsure. I have an outboard kit and took it off due to lack of suspension articulation. Additionally, I see where some even put limiters in their shocks. I thought the point to rock crawling was maximum suspension articulation. Like water over rocks. Tire foams. I took mine out and see a benefit to not running with foams and wonder if anyone does this? Opinions welcome. |
01-22-2012, 06:38 AM | #2 | |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Re: Tech questions-- Slipper clutch, shocks, tire foams.. Quote:
01-26-2012, 01:29 PM | #3 |
Pebble Pounder Join Date: Jul 2011 Location: Belgium
I keep reading about the 'outboard kits",could someone enlighten me please? I know that this is meant to put your shocks more outward,but is there a "kit" available to do this? |
01-26-2012, 01:52 PM | #4 | |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
Yes, you'll need to order this. Losi: Outboard Shock Spacer Kit: MRC: Losi (LOSB1446) | |
01-26-2012, 02:04 PM | #5 | |
Rock Crawler Join Date: Jul 2008 Location: River Falls
01-26-2012, 02:25 PM | #6 |
| Re: Tech questions-- Slipper clutch, shocks, tire foams.. I actually went this route myself. I went to my LHS and got the 2-56 x 3/4" screws, got home and could not get them to slide thru the shock eyes. They were just a hair too big. I picked up a second pack at a different LHS and ended up with the same results. I ended up taking a trip to ACE hardware, picked up some 2mm screws and they worked perfect. This is on a RTR, not sure if the shock eyes are different on a MRCP.
01-26-2012, 03:22 PM | #7 |
RCC Addict Join Date: May 2009 Location: In the warmth!
2mm is the ticket |
01-27-2012, 07:12 AM | #8 |
| Re: Tech questions-- Slipper clutch, shocks, tire foams.. Yup, I had to bore out the eye a bit with a dremel. Sorry I forgot to include that in my post. I like having the 2-56 as opposed to the 2mm, it just feels beefier (y'know, for a little tiny screw )
01-30-2012, 06:12 PM | #9 |
Newbie Join Date: Jan 2012 Location: tryon
whats the biggest spur i can get for my mrc pro, just upped the motor to a traxxas easy start motor,some where between a 380 and a 540, but the stock 10 tooth pinon wont reach and its got way to much top end.
01-30-2012, 08:36 PM | #10 |
| Re: Tech questions-- Slipper clutch, shocks, tire foams.. Wow, that's a big motor! I tried a few different motors, but found the Losi Insane to be the best..great drag brake and great wheelspeed. I use a 10T pinion with a Hot Racing 62T spur...
01-31-2012, 08:17 PM | #11 |
| Re: Tech questions-- Slipper clutch, shocks, tire foams.. Yeah its a Hemi but seems like it acctually works good. The added weight helps too. where can i find hot racing parts at ?
01-31-2012, 08:33 PM | #12 |
Rock Stacker Join Date: Jan 2012 Location: Lakeland, FL
I bought a 62 tooth on ebay.
Tech questions-- Slipper clutch, shocks, tire foams.. - Similar Threads | ||||
SLIPPER CLUTCH ???s | rc dreemer | Axial SCX-10 | 4 | 03-25-2011 12:05 PM |
Shocks and slipper clutch | Tbone | Axial AX-10 Scorpion | 5 | 10-31-2009 10:34 AM |
no slipper clutch? | timeout | Venom Creeper | 3 | 09-14-2009 07:23 AM |
Slipper clutch | donkeykong | Traxxas Crawlers | 9 | 12-08-2005 08:12 AM |
