Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Motor to ESC connectors
Old 02-18-2012, 04:23 AM   #1
Default Motor to ESC connectors
Hello,
Tried searching around couldn't find it.
I was wondering what type of connectors you are using to connect your motor to esc. Thanks.
Nofriendstaco is offline   Reply With Quote
Old 02-18-2012, 05:45 AM   #2
Default Re: Motor to ESC connectors
Hi
I'm using Deans between my HH Mini Torque and my Castle Creation SideWinder Micro but will probably change to bullet plugs when I rewire the motor.
Hope this helps
neiloid1 is offline   Reply With Quote
Old 02-18-2012, 05:56 AM   #3
On my mini, I used mini deans, they are compact and can handle decent currents, but can be trick y to solder up (just check the polarity before soldering).
I used a normal sized deans on the battery to esc.
needs to be small and allow the cables to remain flexible on a mini. Its suprising how the cabling can affect the suspension if its not flexible enough.
just make sure all connections are soldered properly (no dry solders) and insulate properly. (tip - on battery connections - use a female deans connector on the battery = no exposed terminals to short out!)
Gfresh is offline   Reply With Quote
Old 02-19-2012, 06:05 AM   #4
I prefer to solder directly to save weight. Every little bit helps. If you are not comping then weight really isn't an issue though. A lot of others prefer the bullet connectors.
dstrbd1 is offline   Reply With Quote
Old 02-19-2012, 07:48 AM   #5
X2.. Soldering direct is best..
the_ghetto_rig is offline   Reply With Quote
Motor to ESC connectors - Similar Threads
VXL-3s motor connectors? Jus Electronics 5 03-14-2011 03:49 PM
Bullet motor connectors. chevy42083 Electronics 2 10-01-2007 07:45 PM
a need for motor connectors? Stone age Electronics 12 08-17-2006 04:31 PM
EVX - Do I use 1 or both motor connectors? HannibalLecter Newbie General 1 06-13-2006 01:34 PM
