03-02-2012, 04:49 PM | #21 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: EverettY's MRC Pro Build ;) Quote:
03-02-2012, 05:27 PM | #22 |
Pebble Pounder Join Date: May 2011 Location: ithaca
i does not come with the ones to screw in the servo posts on but it does for the battery.for the battery do what i did.put a stud in (with the battery in and cover) all the way in until it sticks out enough to thread in a lock nut in half way(this way you don't have to use locktite on delrin)screw on the lock nut on till it's tight then you all set.this way you don't have to keep talking a screw in and out slowly stripping out the threads.k
03-03-2012, 03:34 PM | #23 | |
03-03-2012, 03:36 PM | #24 |
i used the rc bros 1/10 servo posts.the alum ones.
03-03-2012, 04:05 PM | #25 |
Do you have a link to them?
03-03-2012, 06:19 PM | #26 |
no they don't sell them any more.but ill look around.
03-03-2012, 10:20 PM | #27 |
Ahh man too bad. LMK if you find any anywere.
03-06-2012, 05:54 PM | #28 |
OK so a little update I got my B1r and got it wired up. I plugged in a battery to test all the functions and I found out I have a problem when I turn it on the wheels just start spinning and I have to push reverse to get it out of reverse. What should I do? I've tried adjusting the EPA, the Throttle Trim, and the Exponential, but it still won't fix it. I ordered up a Thunder Power 325mah 2s 65c battery for it and that should be here Thursday or Friday. Once that comes I will have all my electronics |
03-07-2012, 12:14 PM | #29 |
Pebble Pounder Join Date: Nov 2010 Location: Dark Corner
try reversing the throttle on the remote.
03-07-2012, 12:25 PM | #30 |
I've did that yesterday but just haven't gotten around to testing it now :P
03-07-2012, 04:22 PM | #31 |
Ok I think I got it worked out. My battery is coming tomorrow so I'll try and get a video of it. This went together A LOT faster than I was planning .
03-08-2012, 11:30 AM | #32 |
So the ESC didn't end up working so it's now enroute to Tekin I would calibrate it and get it working fine but then when I turned it off and then turned it back on I would have to calibrate everything again. On a good side though my battery came. I stuck it on and decided to put it a little farther back So here is what I'm going to run now. I really need to get BWD's Servo Mount/Battery Guard. |
03-08-2012, 02:03 PM | #33 |
yes you really need to get dons servo mount.it's amazing!YOU ALSO NEED OUTBOARD YOUR SHOCKS!
03-11-2012, 08:37 PM | #34 |
| Re: EverettY's MRC Pro Build ;) |
03-11-2012, 11:19 PM | #35 |
Quarry Creeper Join Date: Nov 2010 Location: livermore california
03-12-2012, 01:47 PM | #36 |
03-12-2012, 07:43 PM | #37 |
I got some STRC Servo Mounts for the BWD Servo Mount/Battery Guard. I also picked up the Losi Shock Outboard Kit.
03-13-2012, 03:36 AM | #38 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
03-14-2012, 11:59 AM | #39 |
So some stuff came today |
03-16-2012, 01:01 PM | #40 |
| EverettY's MRC Pro Build ;) Update Pic Heavy :)
Ok so I've done some work on it recently . Got the wideners mounted up and put on the BWD Servo Mount/Battery Guard. I had to grind down my steering link to get it to work but now it works great! I also got my shock outboard kit today and got that mounted up. I'm just itching to drive this thing but I'm just waiting on my B1R I also made an indoor course for it. Last edited by EverettY; 03-26-2012 at 12:27 PM. |
EverettY's BWD Mini Wedge Low-Pro - Similar Threads | ||||
Oz Bruiser BWD Low Pro Wedge | Oz Bruiser | Axial AX-10 Scorpion | 79 | 03-28-2013 06:39 PM |
Kratos Team BWD Mini Wedge "Low Pro" | Kratos | Losi Mini-Rock Crawler | 73 | 06-15-2012 10:11 PM |
BWD Mini Wedge "Low Pro" | billet works | Losi Mini-Rock Crawler | 61 | 04-05-2012 03:58 PM |
BWD Low Profile Mini Wedge Build | BuckImod | Losi Mini-Rock Crawler | 35 | 09-02-2011 10:05 PM |
