03-16-2012, 03:23 PM | #41 |
Pebble Pounder Join Date: May 2011 Location: ithaca
| Re: EverettY's MRC Pro Build ;)
i bet you like that new servo mount dont ya.how do you like those servo posts?if you gunna run zero ackerman losi's use this. http://stores.intuitwebsites.com/Bil...ing/Detail.bok . you need to grind the link don a little but it works good.with the servo so far to the side you hardly have any steering link in the way at all.
03-16-2012, 03:35 PM | #42 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Ya I'll probably pick that up sometime soon . It's working great right now though. I really like the Servo Posts they are really light and top notch.
03-16-2012, 03:40 PM | #43 |
good ta know!
03-16-2012, 04:02 PM | #44 |
You should get some of those servo mounts if you need some new ones.
03-16-2012, 04:04 PM | #45 |
ill never need new one but ill have to try them.who makes them and do they make 1/10th scale?
03-16-2012, 04:12 PM | #46 |
They are 1/10th scale ones. They are made by STRC here is the link. STRC Servo Mounts. I'm using the RC10 ones but the Wraith ones would work great too.
03-16-2012, 07:20 PM | #47 |
thanks bra.
03-16-2012, 07:55 PM | #48 |
| Re: EverettY's MRC Pro Build ;) |
03-17-2012, 09:14 AM | #49 |
Rock Crawler Join Date: Feb 2008 Location: Copperopolis
That servo / battery mount is sick. Cool progressive design. Clean MRC build, good job. |
03-17-2012, 08:58 PM | #50 |
03-18-2012, 03:03 PM | #51 |
03-19-2012, 11:18 AM | #52 |
Got the B1R on Saturday and I got it running yesterday. I was busy helping some friends move yesterday so I'm going to test it out in just a few minutes . I'll try to get a video but we'll see.
03-19-2012, 01:32 PM | #53 |
video video video video!
03-19-2012, 05:06 PM | #54 |
Ya I'll try but I'm having issues with it right now. The motor runs for a few seconds and than quits for a few seconds and than runs again. The ESC is calibrated fine and I'm running it on a full battery and the gear mesh is find so I don't know what the problem is.....
03-19-2012, 06:08 PM | #55 |
i had a similar problem too.when it stops does the speed control turn off then turn back on again?
03-19-2012, 06:20 PM | #56 |
Kinda I fixed it though. I just changed the Low-Voltage cutoff to 2s and now it works.
03-19-2012, 06:27 PM | #57 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
03-19-2012, 10:19 PM | #58 |
| Re: EverettY's MRC Pro Build ;) Soon I'm still getting used to driving the smaller one since I'm used to driving the 2.2s. I keep hitting the timer button on the TX to do dig and than I'm like "OH duh there's no dig" Well I'm getting better though. The course is challenging but really fun. There will probably be a lot of fails in the video....but hey that's the best part of the video right? LOL well maybe not... I really need new tires and C.I. Foams. And than I need to go bodiless. this thing like to roll over when it's taking steep climbs or steep descents.
03-20-2012, 02:05 AM | #59 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Im glad ya got your esc issue figured out bro. I kinda figured that might be the issue. So...can you pull your battery out easy enough with that new mount? It looks like shes wedged in there pretty well. I actually ran those new BWD wheels on the Wicked Cricket prototype at Nats last year and they DO work killer. Im just not a fan of knuckle weights on a mini and there isn't a ton of room on the wheel for lead without losing some tire wrap. But she was quick without the rotating mass. If you're thinking about bodyless...both the BWD and the Chaotic are killer choices and you wont go wrong with either. Ive run em both along with the Mini Juice & now elusive Wicked Cricket (which I WILL build soon. Poor thing looks sad on my bench) and they both perform. I like the Chaotic because its an improved Pro Roller and a direct replacement for your stock chassis. Chaotic also offers the Ti link set if ya wanna go THAT route. Obviously Im a tad biased in my opinions but like I said...either will treat you well. Keep up the good build bro and let me know how that electricsl issue works out and dont hesitate to hit me up again if ya need some help. J.D. |
03-20-2012, 02:30 AM | #60 | |
| Re: EverettY's MRC Pro Build ;) Quote:
This is about where I ran my last mini. Obviously still low and sitting stinkbug style but it works really well on those steep climbs you're rollin over on. With that short of a wheel base...lower is better. Look at the mini class killin 801 clan...they run belly draggers and MOST run drooped suspension. Ya really dont wanna add too much weight because these little 380 can motors aren't capable of high loads so low and lean works best. Obviously you need to find a happy balance. You want SOME ground clearance but ya gotta decide how much you NEED. J.D. | |
EverettY's BWD Mini Wedge Low-Pro - Similar Threads | ||||
Oz Bruiser BWD Low Pro Wedge | Oz Bruiser | Axial AX-10 Scorpion | 79 | 03-28-2013 06:39 PM |
Kratos Team BWD Mini Wedge "Low Pro" | Kratos | Losi Mini-Rock Crawler | 73 | 06-15-2012 10:11 PM |
BWD Mini Wedge "Low Pro" | billet works | Losi Mini-Rock Crawler | 61 | 04-05-2012 03:58 PM |
BWD Low Profile Mini Wedge Build | BuckImod | Losi Mini-Rock Crawler | 35 | 09-02-2011 10:05 PM |
