03-20-2012, 02:03 PM | #61 |
Pebble Pounder Join Date: May 2011 Location: ithaca
| Re: EverettY's MRC Pro Build ;)
nice mini!
03-20-2012, 08:30 PM | #62 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: EverettY's MRC Pro Build ;) Quote:
Quote: | |
03-20-2012, 08:32 PM | #63 |
| Re: EverettY's MRC Pro Build ;) |
03-21-2012, 12:07 AM | #64 | ||
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: EverettY's MRC Pro Build ;) Thanks bro. Quote:
J.D. | ||
03-21-2012, 12:39 AM | #65 |
You should grab some rx pins, plugs and a set of pin crimpers to shorten those leads. One of the best investments I've made. I use em on every build. Also...do you have to back out those screws in the battery mount to get it out? It looks that way from the pics. Also also...the gear mod I was telling you about to get the most outta that Brood Anarchy is this... Grab an AE RC18 66T spur gear & drill out the center mount to fit the MRC sleeve. I suggest using a drill press or at least a step bit so it stays centered...otherwise you're gonna end up with a nice tight spot in your mesh as the gear wobbles on its mount. Then you'll wanna get a small pinion...I ran a 9t. The BWD motor spacer will help a lot in getting the set screw to mate with the motor shaft. I also took a Dremel to the Anarchy shaft to create a flat spot for a better mating surface. This new gear ratio is gonna zap any speed you had but it will help with the cogging and lack of low end. J.D. Last edited by HARDKNOCKZ; 03-21-2012 at 01:41 AM. |
03-21-2012, 04:22 AM | #66 | |
03-22-2012, 03:59 PM | #67 | |
Ok I'll do that stuff thanks for your help! | |
03-22-2012, 04:01 PM | #68 |
I ordered the BWD Motor Plate and Motor Spacer a few days ago and it is en route to me right now. I also flattened the shocks and inverted them. I can get better twist and it twists much better. I can also climb and descend much better.
03-22-2012, 05:41 PM | #69 |
BWD all the way man!
03-22-2012, 05:47 PM | #70 | |
I personally dont like inverted shocks on any of my rigs. The only REAL benefit IMO is getting that teeny tiny bit of weight in way of the shock oil...lower. My major problem is that when inverted...your piston is now sitting in the air pocket, at the beginning of the stroke, making em cycle somewhat quirky and unpredictable. But if it works for you bro...run em. Just check your oil frequently. J.D. | |
03-22-2012, 05:56 PM | #71 | |
03-22-2012, 08:14 PM | #72 |
It's working great for me right now soooo I'll probable keep running it that way for now until probs come up. BTW did you get my PM J.D.?
03-23-2012, 11:53 AM | #73 |
Just traded for a Holmes Torquemaster Mini 19T so I'll be trying that out too |
03-25-2012, 10:31 PM | #74 |
Look what was on my porch when I got home today . I'll get it mounted up tomorrow and than get some more pics up. |
03-26-2012, 01:15 PM | #75 |
And pics of the Motor Plate all mounted up. |
03-27-2012, 10:53 AM | #76 |
And I got all back in the car . I took some video footage yesterday and I was going to put it all together and make a movie but when I put the memory card in the computer the video's wouldn't show up. They show up when I stick them back in the camera but not on the computer. |
03-27-2012, 01:56 PM | #77 |
yeah billet works!
03-29-2012, 05:22 PM | #78 |
| Re: EverettY's MRC Pro Build ;) HAHA ya I love BWD OK so I got my HH Mini Torquemaster Mini today and I mounted it up and took it out for a test drive. It was working great and than my MRC took a little fall about 1 ft and it went rolling and I picked it up and one of the Losi Rear Bent links had broken :P.....And since it broke right were the rod end connects part of it is stuck in the rod end and I can't get it out and I don't have extra rod ends so I'm out of business for now :( I also did a little trimming to my tires and they perform noticeable better so that is a good thing. |
03-29-2012, 05:48 PM | #79 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Whatever you do, DON'T replace the Losi bent link with another Losi bent link! They are known for breaking way too often and way too easily. Just my 2 cents worth of advice there.......... |
03-29-2012, 07:29 PM | #80 |
get some delrin links from don.they slide over the rocks really smooth!
EverettY's BWD Mini Wedge Low-Pro - Similar Threads | ||||
Oz Bruiser BWD Low Pro Wedge | Oz Bruiser | Axial AX-10 Scorpion | 79 | 03-28-2013 06:39 PM |
Kratos Team BWD Mini Wedge "Low Pro" | Kratos | Losi Mini-Rock Crawler | 73 | 06-15-2012 10:11 PM |
BWD Mini Wedge "Low Pro" | billet works | Losi Mini-Rock Crawler | 61 | 04-05-2012 03:58 PM |
BWD Low Profile Mini Wedge Build | BuckImod | Losi Mini-Rock Crawler | 35 | 09-02-2011 10:05 PM |
