09-25-2012, 11:29 AM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Port Charlotte
| Full size servo
Would using a full size servo with the factory esc cause any problems? Thanks
09-25-2012, 01:54 PM | #2 |
| Re: Full size servo
What size lipo are you running? It shouldn't.. a bec is best way to go.. without a bec, running 2s should be good, the internal bec doesn't have to work as hard to limit power.. if ur running 3s, the internal bec has to limit 11.1v to 5v.. where with 2s the internal has to only drop it a little bit.. at least how it was explained to me at one time.. cc bec... |
09-26-2012, 10:33 PM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Australia
| Re: Full size servo
I`ve just changed my original servo to a full size servo. The ESC got hotter with the full size servo so I have just ordered a Castle creations bec. I will tell you how I go when it arrives. |
10-08-2012, 06:26 AM | #4 |
RCC Addict Join Date: Nov 2007 Location: somewhere
| Re: Full size servo
The bec will help a lot but it is not a have to at least not with mine I ran 6 or so comps on mine with a 645mg and a mini slider motor with the stock esc before I got a bec. The bec will help cooling the esc off some. All on 2s
10-12-2012, 03:12 PM | #5 |
Newbie Join Date: Oct 2012 Location: carmichaels
| Re: Full size servo
i ran my Hs-7954 with the stock esc on stock battery for a while i never had any problems but you wont get the full power out of ur servo with out a bec as lowridinjuggalo had mentioned
12-14-2012, 10:56 PM | #6 |
Newbie Join Date: Oct 2012 Location: auburn
| Re: Full size servo
I am running a full size servo on my losi mrc with the stock battery and stock esc. Only thing is the servo is a little slow but works well.
12-15-2012, 08:33 AM | #7 |
| Re: Full size servo
ittybitty hooked me up with a 7954 servo and a bec. I have not had any problems since. I'd say you do need a bec.
Full size servo - Similar Threads | ||||
Full size servo plate | TAT76 | Losi Mini-Rock Crawler | 3 | 08-30-2010 02:26 PM |
LOSI Carbon Fiber servo / lipo mount - any PICS with full size servo? | mascman | Losi Mini-Rock Crawler | 10 | 12-16-2009 08:35 AM |
full size servo question | h8z2luze | Losi Mini-Rock Crawler | 17 | 09-24-2009 03:18 PM |
DNA Dig Custom Servo Mounts, Full Size or Micro Servo | Kraqa | Axial AX-10 Scorpion | 12 | 09-11-2009 10:17 AM |
full size servo | uberalles | Losi Mini-Rock Crawler | 2 | 09-09-2008 11:54 AM |
