12-21-2013, 03:40 PM | #1 |
DravTech Join Date: Aug 2012 Location: Sweden
| Dravpnir tries to build something small
When my pal BilB told me that he was getting a MRC I got a bit curoius of these small machines. Then just a few days later a suitable candidate turned up at the sales part of a Swedish RC forum it was tempting, but I choose to let it pass. Then when the seller lowered the price I could not resist it. And I cannot leave poor BliB driving all alone next season, right....? So $85 poorer but an MRC Pro richer What got me really interested was that the previous owner had modded the MRC with VP C-hubs, VP Wraith knuckles and axial universals at the front. Otherwise it is more or less a MRC Pro with the overdrive mod. The mod was not perhaps so good executed so I have some clean up work to do and the front is too wide at the moment so I have to do something about that too. Also, as I seem to not be able to leave things in their original state, this one will be quite heavily modded too First thing up is some new wheels. I made some discs when I made some parts in the lathe for my coming sporty and my lightweight Berg. I will put these disc in the mill and finish them. I am planning on making the hex and hub as a part of the outer wheel disc. Thats why there are a thicker area in bottom row of discs. The flat disc on the upper row will become the backside rings. |
12-21-2013, 04:01 PM | #2 |
Oh man, Hell of a deal! Not to mention the chubs and knuckles alone are worth the price to play... I did the mod to mine and it easily has to be the Best mod possible for these little guys, hands down. Can't wait to follow along with the mods |
12-21-2013, 05:34 PM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: Sweden
Dont wanna talk s**t about ppl but this might be one of the reasons the price was right But if someone gonna make that work it's Dravpnir! |
12-21-2013, 06:02 PM | #4 |
For the price of a mrc housing and xr or wraith housing.. ill take it that way for that price! lol
12-22-2013, 12:48 PM | #5 |
Yeah the parts that's on it makes it worth! Hopefully both Dravpnir an i get finished so i can continue with the indoor crawling stop in my basement |
12-30-2013, 04:18 PM | #6 | |
| Re: Dravpnir tries to build something small Quote:
I finished the wheel that was shown in a semi finished condition in the pictures above. The hex is a part of the outer wheel face. But when I made the wheels I forgot that the wraith knuckles are so big so I cannot use the wheels for the front axle... Perhaps I will use them for the rear, but most likely they will end up in "parts bin" Then I have also experimented with using a Mini Revo transmission for the MRC. My big plan was to use that transmission and one of my spare Cobalt 454 Pullers. But I couldn't make it work like I wanted. So that plan is on ice for now. Perhaps I will make a better transmission case for the Mini Revo gears later on (or Berg gears), but right now I have more other projects I want to continue with instead so I will stick with the original transmission. The front axle has been cleaned up and shortened, so now the front width sits at slightly below 8". And I have also ordered that heli 380 motor with neo magnets. I hope it is as good as people say Last edited by Dravpnir; 12-30-2013 at 04:20 PM. | |
12-30-2013, 05:07 PM | #7 |
RCC Addict Join Date: Jan 2009 Location: Bend
Lookin good so far! Too bad about the wheels. BTW, you won't be disappointed in the Xtreme motor. I have one for my build for the coming season, and my daughter's Exceed Maxstone is rocking one. I haven't got a whole lot of drive time with it, but it's punchy, smooth, and precise all in one as far as I can tell. Faster than my Novak setup, with none of the downfalls of brushless.
12-30-2013, 07:14 PM | #8 |
Saaweeet! Just a couple things that will help with max, smooth, steering.. At minimum, shave them ears for anything past 50-55°... The brass "top hats" should be between the chub an knuckle, so the flat disc should act as a washer between the 2.. On to the wheels, which are sick looking and a great idea! I found the same thing with my wheels, I ended up flipping my face, cause the hex are built into the face, that way I could run them. They are only half inch wide at that, which I have found to be the perfect width wheel for the mrc. Maybe you could make ur front wheels a 3 piece wheel or cut ur spacers down to make ur wheels narrow enough to use them the way you made them to work? |
01-01-2014, 10:21 AM | #9 |
On the wheelsproblem, one could buy the xr10 alu knuckles from HR or any of the other brands, cutting the integrated steeringarms should allow the use of them sweet a** wheels!
01-04-2014, 08:24 PM | #10 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I didn't see this coming. Glad you got I'm the mini game. Looking forward to the progress.
01-06-2014, 02:36 PM | #11 | ||||
I received the motor a couple of days ago. I haven't tested it yet though. Quote:
The "top hats" has to be that way I am afraid. I cannot put them on the right why because then the knuckle will not fit... I guess the previous owner didn't have the right bushings or something. I will see if I can find some better ones. Flipping the wheel sides will make the front to wide. Perhaps the 3-piece idea will work, but I got to many ideas to make atm (and too little time), and got a bit tired of the wheels when they didn't work out. So I think I will leave them alone until inspiration strucks again. Right now I am working on a new chassis for the mini. Barry from ClassiCutCustoms was so kind and let me have a drawing of his 2.2 pro Pitbull chassi that I now have modified to suit the MRC (I hope...). I hope I get the time to make a first prototype out of delrin this week. When I happy with it I will send the drawing back to Barry so he can cut a CF version of it Last edited by Dravpnir; 01-06-2014 at 02:38 PM. | ||||
01-07-2014, 03:31 PM | #12 |
What is this? After stealing the spacers and skid from my 2.2Pro comp Berg it looks a bit better It looks even better if I also borrow the panels from my Berg Test mounted the transmission, also showing off the new motor It is a bit to tight in there, but luckily there is material I can easily remove to get that extra clearence that I need. Also my calculations was a bit off so I have to use two lower plates with the cut out for the transmission, or increase the with with 2 mm. Cannot decide which way to go yet... |
01-07-2014, 03:57 PM | #13 |
Cab looks the same size as 2.2! Lol.. Looks pretty sweet! Last edited by winnerone23; 01-09-2014 at 09:39 AM. |
01-07-2014, 04:03 PM | #14 |
| Re: Dravpnir tries to build something small |
01-08-2014, 12:47 PM | #15 |
Rock Stacker Join Date: Jun 2009 Location: Idaho Falls
I will be keeping an eye on this one! Just bought my first mini a few weeks ago from ittybitty and I have had more fun with it lately than my berg. Surprised the 1.9 class is loosing interest, can't figure out why? Keep up the good work!
01-08-2014, 02:16 PM | #16 |
I am waiting for you to take the berg approach to the pumpkin of these axles and get a much smaller axle tube out of it. RickM |
01-08-2014, 02:20 PM | #17 |
I have a set of housings I've cut the stock tubes off of, thinking of going that route^. Funny you bring that up. With 4 bolts, the stock center section would be removable if you built a truss to hold the tubes together. The truss could act as the servo/upper link mount as well. Somebody needs to do it already!
01-08-2014, 11:35 PM | #18 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Ill be running the same motor this season. I picked up 2 of " a more popular" motor and watched them crash n burn at comps this past season. It is big Troy but in hoping it fits right and gives the smooth throttle response you know I wine about in 2.2 |
01-08-2014, 11:55 PM | #19 | |
Who's Troy and fits where? Perhaps the coffee hasn't kicked in yet | |
01-09-2014, 12:41 AM | #20 |
| Re: Dravpnir tries to build something small ^Come on man, you can't say things like that without details...I'm almost waiting on my front axle build to see what happens in the next few months. I know something's gotta give somewhere, and hoping it's before this coming season. The further I get with my new rig, the more I wanna comp it. A bitchin' new front axle may just push me into traveling to do so.
Dravpnir tries to build something small - Similar Threads | ||||
Dravpnir tries to build something even lighter | Dravpnir | EnRoute Berg | 88 | 08-03-2014 02:58 PM |
Dravpnir tries to build something light | Dravpnir | EnRoute Berg | 125 | 04-23-2014 06:01 AM |
small build | irollgen4s | Axial Wraith | 1 | 12-05-2011 08:49 PM |
Anyone build a small lathe? | colonel | Tools, and Procedures | 16 | 01-17-2010 05:52 PM |
