04-27-2015, 06:17 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Shock info for mini builds of ALL types...
Just a quick start to something I've wanted to do for some time. This will become a complete "mini only" shock reference thread in time, and will give you all the numbers you need to know when looking for shocks for your next project. Not necessarily just for the crawler guys, I will start adding pics and more info soon on ALL the mini applicable shocks I come across in my meandering. Even a few options that came from some pretty unlikely sources that would fit scale and go-fast builds quite well... Losi branded billet threaded shocks- Extended length- 82mm Compressed length- 50mm Travel- 32mm Shock body diameter- 8.95mm Shaft diameter- 2mm Mini Late Model billet shocks- Extended length- --mm Compressed length- --mm Travel- --mm Shock body diameter- 8.95mm Spring inside diameter- 10mm Shaft diameter- 2mm Losi Mini T front billet shocks- Extended length- 55mm Compressed length- 40mm Travel- 15mm Shock body diameter- 8.95mm Shaft diameter- 2mm Losi Mini T rear billet shocks- Extended length- 60mm Compressed length- 42mm Travel- 18mm Shock body diameter- 8.95mm Shaft diameter- 2mm *All measured with NO internal or external limiting of any sort. Not even lower spring seats. 1mm should be added to the compressed length and subtracted from the travel measurements if using stock Losi spring seats. Others will differ. If you guys have other bolt on options or missing info to fill in my blanks, post it up! Last edited by 89redranger; 04-27-2015 at 06:20 PM. |
Shock info for mini builds of ALL types... - Similar Threads | ||||
Need good shock info | dontbsalty | Axial Wraith | 1 | 05-12-2013 03:57 PM |
where are the Chaotic Pro mini builds? | bikerj08 | Losi Mini-Rock Crawler | 9 | 12-05-2011 08:41 PM |
JPCustomRCs WK shock mounts info | jbrandt | HPI Wheely King | 4 | 08-16-2007 06:05 PM |
Mini Crusher Info? | tombstone | Chit Chat | 17 | 05-10-2006 02:27 PM |
Shock question.. idea... info... | Double J | General Crawlers | 5 | 02-25-2006 09:06 AM |
