04-15-2014, 10:46 AM | #21 |
Rock Stacker Join Date: Feb 2014 Location: Bradenton
Pictures!!!! |
04-16-2014, 09:37 AM | #22 |
04-16-2014, 10:46 AM | #23 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: MRCP and MCRCP
So how well do they perform being drooped like that? Seems like you'd want at least some spring resistance on there. I mean I run one of my micros that way, but don't think I'd consider doing that with my MRC.
04-16-2014, 12:08 PM | #24 |
They have spring resistance inside the shocks. Rebuilt them with pen springs inside. They crawl like snakes. They're incredibly capable. Still need to work more on the black 4ws crawler but the blue one works great.
04-16-2014, 12:27 PM | #25 |
Quarry Creeper Join Date: Dec 2013 Location: San Diego county
I do a similar setup, full droop front with pen springs, half droop/half sprung rear (pen spring cut in half) and it works great, it's like they were made to run droop, nice pair you have there *thumbsup
04-16-2014, 12:32 PM | #26 |
| Yeah I like the full droop as it feels like a snake driving it. Picked these both up for steals. They really were designed for droop. I figured I'd make one 2ws and keep it looking nice and the other 4wd so I have the best of both worlds. The vanquish wheels are incredibly heavy. I'm pleased with both.
04-16-2014, 12:37 PM | #27 |
You should play with internal limitin to cut down the flex some, it makes the incredibly predictable, mine are limited 4mm I know a lot of others do this as well maybe they will pitch in with thoughts/advice
04-16-2014, 12:43 PM | #28 |
| Yeah I limited the blue crawler much more than the picture. Its set up similarly to the black crawler. I have really gotten these things outside much but that'll be changing soon. Do you know where I can get the screws for the steering linkage. I'm using collars and some extra screws I had and there's too much play in the rear steering. It also has a servo saver on it so on really high grip areas it takes the crawler a bit of movement to allow the wheels to fully move.
04-16-2014, 01:25 PM | #29 |
Maybe check out losi parts house
04-16-2014, 03:50 PM | #30 |
Quarry Creeper Join Date: Aug 2013 Location: Canada
| Re: MRCP and MCRCP
Now you only gotta cut those body posts down so you can recover from a roll-over |
04-16-2014, 03:56 PM | #31 |
Thanks guys yeah I'm gonna cut them down and check losi parts house out for the steering linkage screws. Glad you guys like it so far.
04-19-2014, 12:49 AM | #32 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
| Re: MRCP and MCRCP
Nice pair of mrcs. Ditch the servo savers and go with aluminum servo horns. Best steering mod you can make.
04-20-2014, 02:05 AM | #33 |
| Oh yeah I'm getting rid of that thing. It annoys me but that's what came with the parts I had ordered and I only had a small amount of time to get it all pit together.
06-22-2014, 01:53 PM | #34 |
| MCRC custom! Thoughts? Suggestions and comments? Wheel wideners, different wheels and 4ws. Anyone know how to hide the electronics a bit better? Still need to pull the wheels apart and put some lead weight in them. Last edited by mitchponton; 06-22-2014 at 02:21 PM. |
06-27-2014, 10:02 AM | #35 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: MRCP and MCRCP
Looks really cool all stretched out and low. What's up with the drive shafts? Can't tell what's in there, from the picture. |
06-27-2014, 01:30 PM | #36 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: MRCP and MCRCP
They look to be extended with aluminum tube. Pretty common with the micros. There are only 3 different driveshafts available for micros (original MCRC, Trekker, and Redcat Sumo Micro), and none of them will support a wheelbase much over 4.5-5", therefore you have to extend the stockers...
06-27-2014, 04:16 PM | #37 |
Rock Stacker Join Date: Apr 2014 Location: Houston
| Re: MRCP and MCRCP
Man that micro is sick ! |
06-27-2014, 04:52 PM | #38 |
Pebble Pounder Join Date: May 2014 Location: SF
| Re: MRCP and MCRCP
you need to limit that flex some. add some weight and flip the tires on the blue one. the tread is backwards. for steering look on ebay and get some CVD's if you can find them. it is a bolt on improvement but better. the XR mod is the best by far but just if you want to keep it a little more simple then this is good. |
07-01-2014, 09:49 AM | #39 | |||
| Re: MRCP and MCRCP Quote:
Thanks! Quote:
What is the XR Mod? My goal is for a Micro "Super" and a Mini "Super" Let me know some recommendations. | |||
07-02-2014, 11:59 AM | #40 |
| Re: MRCP and MCRCP |
MRCP and MCRCP - Similar Threads | ||||
Losi MRCP | mitchponton | Micro Scale Rigs | 5 | 06-22-2014 02:23 PM |
Losi MRC or MRCP | BigJon | Losi Mini-Rock Crawler | 13 | 03-21-2012 07:45 PM |
MRCP Servo Mounts? | skullking | Losi Mini-Rock Crawler | 5 | 07-08-2011 05:16 PM |
Back in the Game MRCP | ScalerLover | Losi Mini-Rock Crawler | 3 | 07-05-2011 04:57 PM |
