03-30-2014, 10:37 PM | #21 | |
Quarry Creeper Join Date: Dec 2013 Location: San Diego county
| Liv3mind mrcp Quote:
see now that I could probably go for. Mostly an mrc pro, at least the good bits that I want, hopefully for the right price........i am gunna buzz the classi......maybe my xr will have to wait lol Sent from my Lumia Icon using Tapatalk Last edited by Liv3mind; 03-31-2014 at 12:41 AM. | |
03-31-2014, 07:47 PM | #22 |
You can pm me for details.. Ya know, if your interested.. |
03-31-2014, 08:30 PM | #23 |
| thanks for the offer. I got another mrcp today locally really cheap. Hardly used at all, really no scratches. Has a 18.5 brushless system In it, 2 extra sets of wheels and tires, 3 sets of losi wheel weights, 3 mrcp losi batteries, 2 new sets of axles, all in the original mrcp box, Il post pics tonight ir tomorrow. I think I will be running 1.9 alone in san Diego alone. My xr build can sit back burner for a bit lol |
04-01-2014, 01:52 AM | #24 |
Here is my hack job, this on full droop front half droop half sprung rear, this one will be getting a 7950tg cause that's what I have sitting, of course I gave it the boxer look as now I have come to like it a lot. Ordered some servo guards today (thanks Troy!) I drove through 3 battery packs this evening, 1 before doing the suspension droop setup and 2 after. Holy hell this thing is the funnest rc car I have ever drivin. Doing the droop setup made a world of difference IMHO base on my driving style. Here are some poser shots: |
04-01-2014, 11:03 PM | #25 |
| Liv3mind mrcp
Ok, I pulled the brushless system out and cleaned it and stored it, too bulky and too heavy, will be running sidewinder micros in both cars, with slider motors probably still undecided, unsure of pinion yet, one will be staying relatively un modified and the other will be modded and changed. My first sidewinder micro will be here Friday, so I will try to have the first car up and running by Saturday. Il update as I go along, I'm thinking about going and getting all the mrcp upgrades my lhs still has sitting. I got a losi carbon servo/batt tray today, is there an aftermarket option for mounting front upper links? Anyone have an opinion on the team brood frenzy motors? Good speed and torque? Bolt in without modifying? Thanks in advance for info
04-04-2014, 12:37 AM | #26 |
Well my 2.2p is completely on hold, there are some cool things coming in the 1.9 area of my home office........
04-16-2014, 12:42 PM | #27 |
The parts are starting to show up for a build...........couple more big parts and it will start going together |
04-16-2014, 07:31 PM | #28 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Liv3mind mrcp
Looking forward to a build!
04-21-2014, 01:08 AM | #29 |
Any one know Losb1260, is this the pn for the pinion set that fits the slider motor? Its got the splined output shaft instead of the flat sided shaft? Thanks
04-21-2014, 06:43 AM | #30 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
| Re: Liv3mind mrcp
if the slider motor has a 2mm shaft they will work, you can file a flat on the motor shaft for the set screw
04-21-2014, 09:00 AM | #31 |
04-21-2014, 10:56 AM | #32 | |
Quarry Creeper Join Date: Aug 2013 Location: Canada
| Re: Liv3mind mrcp Quote:
Be carefull when sanding, it takes literally nothing to sand these down and if you sand too much you'll have slack in the pinion. Better sand 1-2 second then test-fit, on mine i even left *some* splines and pressed the metal pinion on the shaft for a really good fit. | |
04-21-2014, 11:25 AM | #33 | |
that's a perfect description if how to do it, thank you very much for going in depth on it | |
05-22-2014, 02:23 PM | #34 |
Pebble Pounder Join Date: May 2014 Location: SF
| Re: Liv3mind mrcp
mini -t springs work great with those shocks gives you just the right amount of articulation |
Liv3mind mrcp - Similar Threads | ||||
MRCP and MCRCP | mitchponton | Losi Mini-Rock Crawler | 43 | 07-04-2014 03:46 PM |
Losi MRCP | mitchponton | Micro Scale Rigs | 5 | 06-22-2014 02:23 PM |
MRCP Servo Mounts? | skullking | Losi Mini-Rock Crawler | 5 | 07-08-2011 05:16 PM |
Back in the Game MRCP | ScalerLover | Losi Mini-Rock Crawler | 3 | 07-05-2011 04:57 PM |
