Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Purchased a rig that's all jacked up
Old 12-08-2014, 10:26 PM   #1
Default Purchased a rig that's all jacked up
So like the title says, I recently purchased a mrc off a friend he had bought off someone blah blah blah. The thing is it's basically a slim chassis with links off a scx10, no spare parts and just all around wrong. I purchased the y links only to find that my chassis is too slim. I've seen plenty of custom chassis on line but can't seem to find anything for sale. Any help would be appreciated
Troublekitty is offline   Reply With Quote
Old 12-09-2014, 12:53 PM   #2
Default Re: Purchased a rig that's all jacked up
https://www.rcpcrawlers.com/product....&cat=40&page=1
Saw this one the other day for 10$ lots of options for link and shock mounting.
Dubnrub is offline   Reply With Quote
Old 12-09-2014, 02:12 PM   #3
I found this. It basically has all the parts I need but it doesn't seem to be for sale anymore
http://www.billet-works.com/build_in...s_-_mini_wedge
Old 12-09-2014, 05:07 PM   #4
E.Y. Designs
If you wait a little while there will be some new ones out soon... if you look up Dravpnir's MRC build I believe his chassis will be available soon
EverettY is offline   Reply With Quote
Old 12-09-2014, 06:42 PM   #5
Location: somewhere near Los Angeles...or a city looking thingy.
Not soon enough. I'm about to fly over there and help him get it into production myself.
OTHGbronco82 is offline   Reply With Quote
Old 12-09-2014, 06:47 PM   #6
Is Tobias working on a new mini chassis!?
winnerone23 is offline   Reply With Quote
Old 12-10-2014, 03:20 AM   #7
DravTech
Dravpnir's Avatar
I think that EverettY means the Pitbull Mini chassis. If you are interested in getting that please contact Barry at ClassiCutCustoms. I only designed the chassis from the CCC 2.2 PitBull and Barry will produce and sell them.
I am
But it will be for the Brood Mini Stubby motor, that me and EverettY got the only two existing examples of, so it will hardly be offered for sale.
Dravpnir is offline   Reply With Quote
Old 12-10-2014, 11:32 AM   #8
The reason I posted that link is because it comes with the servo plates for the front and rear with all the links because like I said this rig has none of the original links and at the moment I don't have a way to fab anything. I'll post pics tomorrow
Old 12-10-2014, 02:23 PM   #9
This chassis is available from bwd, you just need to enter their online store
There should be a big thing saying click this to enter the online store
JAYDEN1999 is offline   Reply With Quote
Old 12-10-2014, 03:36 PM   #10
Originally Posted by Dravpnir View Post
I am
I'll trade ya a kidney for it.
Old 12-11-2014, 10:21 AM   #11
No way!!! I totally just learned something new. Come on dude. I've been all over that site and it's not available
Old 12-11-2014, 03:12 PM   #12
MRC Wedge Replacement Side Plate - Billet Works Designs
It's just the side plate, but it's a chassis. You just have to buy two and make a skid plate.
Old 12-11-2014, 06:06 PM   #13
I would still need the links and I'm having trouble finding those
Old 12-11-2014, 08:04 PM   #14
Make some of your own. I got some delrin from CKRC a while back before they changed owners. It was a 2.5-ish mm inner diameter and a 1/4 or 3/16 outer if I remember correctly. You could always just buy some delrin rod and then drill it yourself too. I chose delrin because it cut real easy and cleaned up easily too with just a dremel.
Old 12-12-2014, 02:53 AM   #15
It isn't hard to make your own links. You can use these items to make it besides a vise, saw and sandpaper to clean the ends:
Threaded rod inside (stiffer)
McMaster-Carr Delrin tube. 4MM is .158" so it is a little bit of a tight fit but if your patient you should get the material to thread in
McMaster-Carr stiff rod
McMaster-Carr less stiff rod
Using threaded rod ends (less stiff but lighter)
McMaster-Carr the tube has a small ID that can easily be tapped to M3. I did this once on a job to save time and it worked great although the outside of the material IS a little bigger but that is no biggie.
threaded studs (you supply those)
McMaster-Carr M3 tap. Treat this guy nice and it will last an eternity. Don't go with cheap taps... they are a nightmare
It isn't the most convenient to make your own links at first but once you learn it is pretty easy to do and in the end if your links aren't perfect you can adjust by threading/unthreading the rod ends!
Crawling Calvin is offline   Reply With Quote
Old 12-18-2014, 11:33 PM   #16
If you're ok with a 3d printed skid (I have been running 3d printed skids on my own mini's and micro's for over a year now without issue), I have everything else still in stock to put together a full brand new mini wedge low pro kit
BW
billet works is offline   Reply With Quote
Old 12-18-2014, 11:45 PM   #17
I have yellow and black printed ABS skids
Old 12-19-2014, 08:15 AM   #18
sgl
If you end up making links, I can get you the measurements. I run a bone stock pro ( except bent lower links) and a scratch built scale 1985 bronco based on mrc-pro running gear. I may have some unused stock links around as well.
Scott
sgl is offline   Reply With Quote
Old 12-20-2014, 09:56 PM   #19
BW
Sounds good. I really just need to put up some pics of this Frankenstein of metal. This thing needs a good looking over
Old 12-22-2014, 05:24 PM   #20
Right side
Left side
Under side
Rear shock
Fwd shock un compressed, fully extended
Fwd shocks compressed
Purchased a rig that's all jacked up - Similar Threads
Now that's jacked up. ThinkTank Chit Chat 12 09-29-2008 04:51 PM
k2 jacked up chevy 454ss toomanyrcz 2.2 Scale Rigs 9 10-09-2006 05:09 PM
Maxx axles... To jacked? HauntFreaks.com Traxxas Crawlers 7 01-21-2006 01:04 PM
