Project Phoenix 4 Attachment(s) I recently got hold of a pile of used MRC parts, and, having a look at my parts bin, it`s time to bring these parts back to life "thumbsup" This comes right in time as a christmas gift for a young lady :) As this will be built (mostly) out of abandoned parts, I call it the "Phoenix" :mrgreen: So let`s have a look at what we got: Attachment 303968 Attachment 303969 - two gearboxes with stock motor - two axles - lower and upper links (the hated Y-links) - two not so good looking driveshafts - four shocks (missing upper balljoints) - chassis plates and body posts - body (nearly full intact) - stock servo - battery tray And that`s what`s laying around: Attachment 303970 Attachment 303971 - set of slightly used wheels - stock receiver - stock esc - HS-225BB servo - Turnigy U-BEC - LiPo low voltage alert - another (new) stock motor - 3Racing CVDs (as the Losi CVDs are discontinued :cry:) - Spectrum radio (steering doesn`t work - we will see if it can be fixed) This will be a fast build, never the less I plan on modding the suspension to a quick and easy four-link, as the body roll caused by the stock Y-link can be a pita. Better steering will be achieved by using CVDs over the stock dog bones and the "mighty mini" Hitec servo, which, powered by the Turnigy BEC set on 5V can strip the M2 screws out of the stock plastic knuckles :twisted:. The BEC can also set on 6V, but this would be to much until the knuckles and links are upgraded. Next will be cleaning, disassembly, lots of grease ... you know the drill :lmao: Stollenritter |
Re: Project Phoenix 9 Attachment(s) Starting with examining the gearbox: Attachment 303986 Everything looks nice inside, so: grease please :ror: Attachment 303987 Next to the axles: Attachment 303988 After disassembling and cleaning comes the first modification. I shorten the small noses on the knuckles, which act as a bump stock and limit steering angle. Attachment 303989 For comparison, left side stock, right side modded: Attachment 303990 And in action: Attachment 303991 This mod is only usefull in combination with the CVDs. The stock dog bones won`t go any further regardless modded or not. CDVs in place: Attachment 303992 Attachment 303993 Next mod, preparation for the four link. Drilled and countersunk the servo plate: Attachment 303994 This will be the attachment point for the new upper links. |
Re: Project Phoenix 7 Attachment(s) Started modding the chassis. Bent the upper chassis corners inward: Attachment 304057 And attached the chassis plates back to the gearbox / skid plate: Attachment 304058 Attachment 304059 Next are the upper links. The links are made from 3mm solid rod stainless steel. Attachment 304060 Attachment 304062 Attachment 304061 I made some cross braces from 1,5mm aluminium sheet. The braces are fixed to the chassis with ball screws from the shocks. Attachment 304063 I have to scrape some more rod ends together for the front axle now ... :ror: |
Re: Project Phoenix 10 Attachment(s) Next up are the shocks. Attachment 304351 Cleaning and refilling with 27 wt shock oil. Attachment 304360 Made a quick home brew outboard shock kit :ror:: Attachment 304352 Looking nice so far: Attachment 304353 And then - BAM! My wife found a "more suitable" christmas gift for the young lady :shock: Ok, nothing wrong with that. That leaves me with a very nice set of MRC axles :ror: I have the dim feeling this project will run into a comletely different direction now :mrgreen: Let`s see what we have: a chassis Attachment 304354 A Subaru Brat body from my younger days of rc cars: Attachment 304355 Set of SDi 1.9 Trail Docters: Attachment 304356 Which look nice on the chassis ... Attachment 304357 ... and not even too bad with the body on ;-) Attachment 304358 Attachment 304359 All in all not what it was ment to be, but hey, that could be a fun little rig! :):):) |
Re: Project Phoenix 8 Attachment(s) I recently had some time for the Mini, so I started to set something right. I allways hated the poor steering geometry of the MRCs. Due to negative Ackermann effect the outer wheel is turning further inward than the inner wheel. There are some zero-ackermann knuckles available, but that`s only half the battle. This is how it looks stock: Attachment 307058 Attachment 307059 To get a positive Ackermann effect, the easiest way is to draw a line from the pivot of the knuckles to the center of the straight / rear axle. The fixing points for the steering rod have to be on that line. So I started a little sketch (dimensions in mm): Attachment 307060 107mm is the width between the pivots of c-hub and knuckles of the front axle, 215mm is the MCR stock wheelbase and 245mm is the wheelbase for the Subaru. I made some simple knuckles with interchangeable steering arms: Attachment 307061 As the drilled holes for the bearings go straight through (for the ease of manufacturing), I had to use flanged bearings to prevent the CVDs popping out: Attachment 307062 The outside bearing is a standard ball bearing: Attachment 307063 Attachment 307064 Complete knuckle with steering arm on top. The knuckle is made from of simple stainless steel pieces welded together, the steering arm is made of aluminium. No perfect beauty, but easy to do without a lot of machinery: Attachment 307065 |
Re: Project Phoenix Awesome work sir! Continue on and keep up with the Great pics! |
Re: Project Phoenix 5 Attachment(s) Front axle complete with positive ackermann steering and new steering rod: Attachment 307066 Steering angles for comparison: (new) Attachment 307067 (new) Attachment 307068 (stock) Attachment 307070 A further benefit is the "behind the axle" steering rod, this will give some more clearance up front :) Attachment 307069 |
Re: Project Phoenix Quote:
Re: Project Phoenix Awesome work on that steering! |
If there is some interest, I could post a few more detailed pics and a little sketch so people can build their own "positive" ackermann knuckles. Just let me know. |
Re: Project Phoenix Digging those knuckles "thumbsup" |
Re: Project Phoenix 1 Attachment(s) Quote:
I got some time to do start with the drawings. The first one will show the difference between the stock knuckles and the selfmade knuckles. To simplify manufacturing, I replaced the welding joint by a bolted connection. This cannot be seen in the first picture due to the sectional representation, but we will take care about this later. The upper one is stock, the lower one is modified: Attachment 309801 The next big difference is also justified by the ease of manufacturing. The stock knuckles have the seatings for the ball bearings done from either side, so there is a small "truss" left in the middle. So the bearings have to be put in from each side. This is neccessary to prevent the shaft from moving out of the axle housing. As I haven`t been able to mill the seatings from different sides, a have a straight through hole through my knuckles. To prevent the shaft from moving out, I used a flanged bearing on the inner side, which can be seen in the lower picture. To take care of the thickness of the flange, I had to offset the distance for the kingpins to align the kingpins with the center of rotation of the CVDs. This is just for explanation, all these calculations will be respected in the later drawings. The attentive observer will have noticed the small green spacer between the ball bearings in the lower picture. This is a small ring made of paper-clip wire (0.6mm diameter). This spacer is a must to prevent the bearings to be jammed togeher. As some of you will use 3Racing CVDs, they have a little bug. The aluminium sleeve is to long and will also jam the bearings. The aluminium sleeve has to be shortened by just about 0.5mm. I have done this by simply shaving it on a piece of sanding paper. In the picture above the sleeves are shortened. So this is a lot of information and I hope I haven`t butchered it up with my poor language skills. For any questions, feel free to ask. |
Re: Project Phoenix I have CVD's so that isn't an issue. It all looks good. Can't wait to get some measurements and make some of my own."thumbsup" |
Re: Project Phoenix 1 Attachment(s) So, first part is the center piece of the knuckle. This one can be made of steel, brass or aluminium, whatever you have at hand or prefer to work with. Mine are made of steel, as I wanted to weld them to the lower brackets. Steel will add about 2.9 times more weight to your axle as aluminium. Brass will be 3.1 times heavier than aluminium. Attachment 309891 Dimensions are in mm, projections of sideviews are "metric", which is opposing referred to the imperial projection method (which in fact is irrelevant for this part, as it is symetrical in two axis). |
Re: Project Phoenix Finally got my computer up and running again. I'll see what I can come up with in auto cad so I can have them machined in brass."thumbsup" |
Attachment 309967 This would have a weight of 10,4g. A nice kind of knuckleweight "thumbsup" |
Re: Project Phoenix Love the design! Couldn't a larger bearing be put into place with this as well? |
