12-09-2015, 08:24 AM | #21 |
Newbie Join Date: Mar 2011 Location: painesville
| Re: ECX Temper
what servo mount did you use for the rear axle?
12-15-2015, 09:10 PM | #22 |
Newbie Join Date: Nov 2015 Location: port alberni
| Re: ECX Temper |
09-10-2016, 01:54 AM | #23 |
Newbie Join Date: Sep 2016 Location: Sacramento
| Re: ECX Temper
Hi there, I am curious how you got the side mounts to top mounts, What did you use to fit that body on there ? Do you also happen to know if a e-revo 1/16 scale body will fit |
09-25-2016, 09:36 AM | #24 |
Newbie Join Date: Sep 2016 Location: Houston
| Re: ECX Temper
So far, I am impressed with my Temper. Box stock still. Did open up the body mount holes a bit with a reamer so the body goes on easier. And reamed a hole in the cowling just ahead of the windshield to access the ESC on/off switch. I feel the Temper is worth the price for what I got. That said, the extent of its crawling has been my 4x4 workshop rock table. I've yet to get it out on the backyard course. The pistol grip radio is really nice. Surprise there. Throttle response is a bit 'jerky' in reverse. The Temper chassis/body takes a 'torque set' to the left during operation. Looks a little strange, but getting used to it. I measured the turning circle at 58" left turn and 57" right turn. That's with 1/4" clearance still remaining to the links. That gives me a tight enough radius to use on my indoor rock table. Thinking my first mod is to 4WS/AWS. Mechanically, it looks easy enough to do. Electronically, I'll have to research that. arnieH Last edited by arnieH; 09-25-2016 at 09:40 AM. |
11-03-2016, 08:05 AM | #25 |
| Re: ECX Temper
Completed the 4WS mod to the Temper and took it for its first test drive this morning. Up side: turning circle is down from 58" to 41". That really helps on my 4'x4' rock table. Down side: more torque lift on the right front. While about it, upgraded to a Spektrum radio/SR410 receiver and Axial AE-5 ESC. Adjusting a Spektrum is new to me, but getting the hang of it. No on/off switch on the AE-5. Axial relies on battery plug in for the power up. Not sure I like that. Guess I'll get used to it. Cheers, arnieH |
11-11-2016, 08:45 AM | #26 | |
Quarry Creeper Join Date: Oct 2016 Location: West Michigan
| Re: ECX Temper Quote:
11-17-2016, 05:11 PM | #27 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Re: ECX Temper
I'm contemplating a new chassis to transfer parts from my Slickrock. Is the ECX Temper close enough to the Losi MRC that I could transfer the axles, center gearbox, and aluminum shocks without hacking the Temper's chassis to bits?
01-02-2017, 05:55 PM | #28 |
Newbie Join Date: Dec 2016 Location: BEND
| Re: ECX Temper |
01-02-2017, 06:37 PM | #29 |
| Re: ECX Temper |
01-03-2017, 06:31 PM | #30 |
| Re: ECX Temper
I tested it on an incline. No go. Still twists, like mad. It was worth a shot. I have a plan to triangulate the lower links. From what I've been told by my 1:1 crawler builder friend, that's the direction I should go. I also want to move the shock mount locations on the frame so they are more vertical. I have some tools at work that can help. I know I'm brand new here, but if I'm successful, I'll post pics. |
01-03-2017, 11:59 PM | #31 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: ECX Temper
4 linking at least the rear and moving the shocks outboard of the chassis and on the axle. Then play with tuning of the shocks. torque twist will be minimal along with flipping that transmission. At least all that worked great on my old mrc rtr.
ECX Temper - Similar Threads | ||||
Temper Tantrum Clod-Pounder | hellbounder | Mega/Monster Trucks | 18 | 06-23-2015 06:24 PM |
New ecx buggy | BOB66 | Newbie General | 0 | 01-29-2015 06:23 AM |
Purpose Built: Tundra with a Temper | Desert Rc | 1.9 Scale Rigs | 47 | 08-18-2011 07:55 AM |
fat paintball kid temper | grizz | Chit Chat | 13 | 09-21-2008 06:06 PM |
