01-03-2017, 10:27 PM | #41 |
Newbie Join Date: Dec 2016 Location: BEND
| Re: ECX Temper scale test and tune
Moving the shocks more vertical with the extensions, how much better has the TT been? In shock form it's ridiculous. Thanks for the thread. Pretty cool. |
01-15-2017, 06:55 AM | #42 | |
Quarry Creeper Join Date: Jun 2005 Location: NW Ohio
| Re: ECX Temper scale test and tune Quote:
I purchased the 2mm aluminum in a little sheet, 6"x9" maybe from my local hobby shop. Cut it out with a bandsaw but a dremel would work too. | |
01-15-2017, 06:59 AM | #43 | |
The TT is mostly gone with this setup. I'm running a semi droop suspension. I put ball point pen springs inside the shocks under the pistons. This helps to keep the truck upright if it flexes over center. | |
01-24-2017, 08:15 PM | #44 |
Newbie Join Date: Dec 2015 Location: concord
| Re: ECX Temper scale test and tune |
02-21-2017, 10:20 PM | #45 |
So this is the stock set-up for the ECX Temper. It has a really bad torque twist. I've been talking with my rock crawler builder friend about how to hopefully fix it. So if you look at the shock mounts they are under the frame way too much. He suggested getting the shocks stood up since that's the way they build them. So with his help on the plasma table and another friends welding skills, we came up with this. The shocks are stood up. This will lessen the amount of flex. In this case that's good. The ECX has way too much flex which lets it tip over easily. Now it sits lower and has more dampening on the shocks. It is stiffer for sure. The quick test for torque twist showed that this helps. I have not crawled on rocks yet, but I'm guessing it will be better. No it's not polished. What's the point? It will soon be dirty anyways. |
02-22-2017, 08:02 AM | #46 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
Please keep us posted on your findings once you take it out for a good crawl
02-22-2017, 06:48 PM | #47 |
Okay. I just crawled my rock coarse at home. I'll tell you what, this mod is a must do. This ECX is crawling the same stuff as my Wraith. Not all the obstacles, but most. The difficult climbs were a no go but they are technical for the Wraith. I found no torque twist. None. One climb is on a slick face where it sends you left and you need to turn right. The stock set-up would lift the right wheel in the air and flip over before you even got to the climb. Now it makes the face and will allow wheel spin to manipulate the line. Then I have a tight, short canyon trail that's got a split at the end that is about 16" tall. The rocks dwarf the ECX and it makes it. I cannot believe the difference. You can actually use it now like a 1/10, sort of. The Temper should be built like this stock. It's great fun now. |
02-22-2017, 08:41 PM | #48 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
For what it's worth the ECX is a rebadged HSP Kulak crawler. The Redcat E16 is also the same unit. HSP Kulak Redcat E16 Sent from my SM-G930F using Tapatalk |
02-23-2017, 10:48 PM | #49 |
02-27-2017, 05:10 PM | #50 | |
Rock Stacker Join Date: Jan 2017 Location: bay area
| Re: ECX Temper scale test and tune Quote: nice vids.......i thought for sure that thing was done and stuck in the second vid, but it got out ok! Last edited by baycrawler; 02-27-2017 at 05:19 PM. | |
02-27-2017, 06:34 PM | #51 |
I'm surprise it made it too. Those rocks are way bigger than the buggy. I just picked up some HH Rover 1.9 tires. They are the same diameter as the stockers. I need to get some wheels ASAP. But they are super soft and super sticky. They should help with grabbing rocks instead of spinning on them. I'm hell bound to make this rig work right. I'm on the right track so far. Need grip and weight. More weight. I don't want wheel weights. I want to keep weight unsprung too. Any ideas? Plus this rig needs some go juice. I plan to get a peppier motor. The HS guys were like, "you can't do anything to help with more speed". I bet they're wrong. Is the 2s 7.4v LiPo a no go? I've read that others have had success with them with no mods. I would install a horn or cut off if it works. |
02-28-2017, 09:09 AM | #52 |
Rock Stacker Join Date: Feb 2017 Location: Merton
Mine crawls great with stock suspension (thinner oil), extra weight, flipped electrics tray, trimmed/lowered body. Drives just as good as my buddies Losi MRC. I run 2s lipo and a 370 motor with a dynamite 60a controller. Its overkill and speed doubled, but I like having the extra power. I ran it on 2s lipo when it was stock but it didn't really benefit from it. |
03-01-2017, 08:21 PM | #53 |
With the 2s, did you get longer run times? That' really what I'm looking for.
05-09-2017, 03:22 PM | #54 |
Newbie Join Date: Nov 2015 Location: port alberni
Ill post some pics of my sons tonight when I get home. We went a bit crazy with it. 4ws, mamba micro x with 2s battery, wheel wideners, 1.9's, all the horizon accessories, believe it or not running the motor backwards helped with torque twist as well as just putting zap straps on the shocks on one side to increase the preload. The thing flies now and crawls very well compared to my scx10. Upgraded radio and transmitter, hitec servos on both ends.
09-11-2017, 06:08 PM | #55 |
Newbie Join Date: Jan 2017 Location: London
| Re: ECX Temper scale test and tune What do you guys mean by "Running the motor backwards" I've looked at mine and can't figure out how you would do that without flipping the transmission around too. Maybe I'm over thinking this.
09-11-2017, 09:03 PM | #56 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
| Re: ECX Temper scale test and tune Thats it. literally un screw the skid from the chassis (trans and motor still attached) and replace turned 180. Will also need to swap the motor wires around.
09-12-2017, 10:43 PM | #57 |
Newbie Join Date: Sep 2017 Location: Canada
I just got this truck and sorry, I'm a total newb, but why would flipping the motor do anything? The truck seems symetrical..
03-14-2018, 02:54 PM | #58 |
Newbie Join Date: Mar 2018 Location: North Aurora
Old thread, I know. I have searched. I cannot find them. What are those rims/tires? They look amazing! Thank you. a Link would be great?> Bigern |
03-14-2018, 08:18 PM | #59 | |
Sent from my SM-G930F using Tapatalk | |
03-14-2018, 09:27 PM | #60 |
On another note I picked up one of these basically brand new for $50 recently. Thinking it will probably get stripped for parts though lol. Sent from my SM-G930F using Tapatalk |
ECX Temper scale test and tune - Similar Threads | ||||
ECX Temper | spectre | Losi Mini-Rock Crawler | 30 | 01-03-2017 11:59 PM |
Ecx temper upgrades | rehnjames | Losi Mini-Rock Crawler | 4 | 01-06-2016 03:40 PM |
ecx temper upgrades starting tomorrow hopefully | Chewitt214 | Newbie General | 19 | 12-28-2015 06:44 AM |
Anyone down for Dakar Test n Tune 2/25 or 2/26? And some scale trail runnin with Rigs | sandbaggerAx10 | Nevada | 7 | 02-23-2012 08:18 PM |
