overdrive mod in clone? So I'm doing some research I loved my mrc before trading it, and picked up a little known scale rig which uses 1/18 axles which research has shown the axles look like the everest 16/ maxstone 16/ templer 18. And I read in here where someone said that people are using maxstone diff in there comp rigs. So that been said has anyone done the mini e-revo pinion to overdrive there mrc clone? And for those that will ask about the scale rig here is a link. RGT Hobby - ROCK CRUISER And also research has soon it a clone of the ecx Barrage 1.9 4WD Barrage Brushed: RTR (ECX01009): ECX RC |
Re: overdrive mod in clone? I had the morning off, so I dug deep in to the RGT axle. I recently found the ring gear that was left over from when I did my overdrive mod to my old mrc. Well I believe it will work, the rgt pinion fits the mini e-revo ring gear. Now picture proof http://i613.photobucket.com/albums/t...ps8kkyitia.jpg http://i613.photobucket.com/albums/t...psomooyxsr.jpg So I'm confident that the overdrive mod will work in this clone axle. Just need to get a pinion and see. Which the only thing I don't know is pinion shaft fitment but can find a bearing to fix that if need be. |
Re: overdrive mod in clone? Pinion gear showed up yesterday, need to install still and give it a test. |
Re: overdrive mod in clone? Put it in and work fine. Just need a new drive shafts. Old pinion out put is 5mm and od gear output is 4mm. I did fit the drive shafts and gave a little test before it popped off. It works good. |
