12-06-2016, 02:21 PM | #41 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| Re: Total Zero!!!! LOL!! Thanks Curcal! Oh trust me, I'm not opposed to building a Super and I will build one, I just didn't want to pony up that cash this winter and only 1 guy in our club has a Super. They are cool as hell!! We have an indoor place we can comp in the winter and the mini is the perfect rig for that place.
12-06-2016, 05:57 PM | #42 |
| Re: Total Zero!!!!
I've been racking my brain on a clean and easy way to mount electronics for this rig considering the fact that there is not much space to do so. Well I came up with an adjustable clamping style mount made out of delrin. . . . . Sent from my iPhone using Tapatalk |
12-07-2016, 01:21 PM | #43 |
Pebble Pounder Join Date: Aug 2014 Location: Middle
| Re: Total Zero!!!!
This thing is continuing to turn out rad! Really cool electronics mount! I may have to copy that for my mini |
12-07-2016, 01:46 PM | #44 |
| Re: Total Zero!!!! Thanks! The mount works really good. I tapped the hole through the back part of the mount (black part) to M3 and countersunk the screw in the face of the mount and when you tighten it down it grips even better than I thought it would!
12-09-2016, 11:52 AM | #45 |
| Re: Total Zero!!!!
Time for tires and wheels! I decided to make some 4.25" Rovers using Axial Ripsaws for the sidewall. They are mounted on Dravtech 1.9 Cyclone wheels with printed centers. . You can see the size difference if a stock 1.9 Rover on the left and the new tire on the right. . . . . Sent from my iPhone using Tapatalk |
12-10-2016, 01:31 PM | #46 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
| Re: Total Zero!!!!
hm... Do i expand my stock losi mini tires or do i shrink my 2.2 moabs? Great looking build! getting lots of ideas for my mini stuff thats coming in.
12-11-2016, 02:32 PM | #47 |
| Re: Total Zero!!!!
Time for electronics. For the esc I went with a Holmes BR mini, Protek 160t, 3ch Receiver, and 2s Nano-Tech 300mah 45-90c packs. Time to smash everything down to fit in this small cockpit. . Servo is wired directly to battery input so I don't need to add a bec and it gets a constant 7.4v. . All smashed down nice and neat. . Fits nicely on the mount I made. . . Sent from my iPhone using Tapatalk |
12-16-2016, 07:22 PM | #48 |
| Re: Total Zero!!!!
Panels cut, painted and installed! This 1.9 is ready to comp! . . . Sent from my iPhone using Tapatalk |
12-16-2016, 07:32 PM | #49 |
Newbie Join Date: Dec 2016 Location: Midwest
| Re: Total Zero!!!!
That is awesome!
12-17-2016, 04:52 AM | #50 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Re: Total Zero!!!!
One sexy beast You will need to add weight now Tungsten putty and lead to the front |
12-17-2016, 02:08 PM | #51 |
| Re: Total Zero!!!!
Dayum Butch!!! Looks like I need to get my mini Mantis, up, running, and ready! You, Stinkass, Dan, Bob, all rocking it out! |
12-17-2016, 02:21 PM | #52 |
| Re: Total Zero!!!! |
12-25-2016, 07:34 PM | #53 | |
Pebble Pounder Join Date: Dec 2014 Location: Abq
| Re: Total Zero!!!! Quote:
12-26-2016, 02:13 AM | #54 |
| Re: Total Zero!!!! Thanks!! I used the shims for the ring and if I remember correctly I think I ended up using 3 shims. I believe I put 2 on the non gear side and 1 on the gear side. I just kept playing around with the side to side space until I had nice smooth gear engagement, not too tight and not so loose that it would slip in a bind.
12-26-2016, 09:44 PM | #55 |
| Re: Total Zero!!!!
OK thanks man.. I took a shot at making this UD pinon out of an XR10 transfer gear. Seems to spin smoothly. Just have to figure out if I run OD/UD, OD/Stock or Stock/UD.... Any experience with this? |
12-28-2016, 07:14 AM | #56 | |
01-16-2017, 11:28 PM | #57 | |
01-17-2017, 01:31 PM | #58 |
| Re: Total Zero!!!! Motor and gearing are working well. Seems to be a good combination. These motors are pretty cheap to buy also but the shipping takes a while since there are no US distributors and you have to order from China. The motors are about $10 each so I just bought 2 so if one craps out I have another ready to go.
03-31-2017, 11:46 PM | #59 |
Newbie Join Date: Dec 2014 Location: Perth, Western Australia
| Re: Total Zero!!!!
The motor looks good where abouts did you order it from? I cant seem to find a seller for them
04-02-2017, 09:34 AM | #60 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
Total Zero!!!! - Similar Threads | ||||
Total amateur in need of help! | totalamature | Tamiya CR-01 | 11 | 11-18-2012 07:37 PM |
Total Frustration!!!! | blckgnx | Newbie General | 15 | 06-03-2011 09:47 AM |
Total Weight | Cycleeric | EnRoute Berg | 14 | 04-20-2011 08:48 PM |
Ok Total newb ? | Goose | Newbie General | 10 | 02-12-2009 06:05 AM |
