02-27-2017, 05:21 PM | #1 |
Rock Stacker Join Date: Jan 2017 Location: bay area
| adding weight and grease
i was looking to add some weight to the front and maybe back. where and how much do you guys add? also........do i need to open up the axles and tranny to grease them? if so, what grease do you guys use? looking forward to the responses! |
02-27-2017, 08:57 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: adding weight and grease
Weight is a personal preference. I have no idea where you should start as I have no clue how much weight is in my wheels nor do I care since it works. And as for grease, yes you'll have to open up the axles and tranny. I use marine grease since it sticks really well and is waterproof. Just don't use too much as it can cause extra drag and possibly make things run a little hotter(electronics).
02-28-2017, 08:20 AM | #3 |
Rock Stacker Join Date: Feb 2017 Location: Merton
I have sticky weights under the servo mount on my temper, seems to help along with weighted wheels.
03-01-2017, 04:56 AM | #4 | |
| Re: adding weight and grease Quote:
what is considered to much or just enough? | |
03-01-2017, 04:59 AM | #5 | |
ah...under the servo mount, that's a good place! i didn't really look there as i didn't think there was enough room. but just looked more carefully, and can probably stick a few in there. how much weight did you put there? also, how/what did you weight the wheels with? | |
03-01-2017, 06:34 AM | #6 | |
03-01-2017, 08:17 PM | #7 |
| Re: adding weight and grease |
03-01-2017, 11:44 PM | #8 | |
actually, i was referring to how much grease since you had mentioned to make sure i don't add to much? | |
03-01-2017, 11:46 PM | #9 |
also, what weight shock fluid are you guys using front and rear? or what's a good base weight to start with? |
03-02-2017, 06:30 AM | #10 |
The MRC Pro manual says 30wt that's what I have for my Associated T4 and B6 2wd trucks, so thats what I put in them. I may go a little lighter.
03-02-2017, 07:14 PM | #11 |
| Re: adding weight and grease Ah, lol. Just enough to cover the gears. You don't want to pack the thing full. But you also don't want dry. I usually go through and give one gear a good complete coating on the teeth and then put it in with the other gears and rotate it a couple of times. Then I add just a tad more to make sure there's no bare metal.
03-08-2017, 12:59 AM | #12 | |
awesome, thanks! | |
adding weight and grease - Similar Threads | ||||
Adding Weight | monkeyracing | Tamiya XC/CC01 | 5 | 11-12-2012 01:44 AM |
Adding weight??? | BigMack | Losi Mini-Rock Crawler | 5 | 11-21-2011 03:02 AM |
adding weight | Briguy-01 | Team Losi Comp Crawler | 11 | 12-28-2009 02:43 PM |
Adding weight | Drey | Newbie General | 13 | 03-24-2009 04:12 PM |
Adding Weight | 93yj6044 | General Crawlers | 11 | 05-23-2006 07:42 AM |
