![]() | #201 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| ![]() I'm not sure I want to know what you did to those poor little foxes.
![]() | #202 | |
| ![]() Quote:
I haven't looked in the Baja Rey's shocks yet; do they have bladders or just O-rings? | |
![]() | #203 | |
Pebble Pounder Join Date: Jul 2016 Location: NCSD
| ![]() Quote:
They got and oring, plastic cap, and a collar that holds everything in place. Than theirs a bleed screw. After filling shocks to rim and assembling them their is still air inside the cap portion of the shock and had to fill that up with a syringe. Funky... | |
![]() | #204 |
| ![]() Last edited by TTDRIVER13; 08-01-2016 at 08:35 AM. |
![]() | #205 |
| ![]() Um...if you fill the shocks completely with oil, there will be no room for the shock shafts inside the shock bodies. There has to be some air that can compress to accommodate the space the shafts take up when they slide into the shock bodies. I prefer it when the air is separated from the oil by rubber bladders, though I've heard some people prefer the air to be exposed to the oil so the shock pistons can churn the air into the oil. That temporarily thins-out the shock oil when driving on rough ground. I've never liked that tuning trick though; I want my shocks to behave the same on all terrain, and I'll adjust my driving style instead.
![]() | #206 | |
| ![]() Quote:
After I filled them up is when I bleed them to my desired rebound, so some of it came back out. | |
![]() | #207 |
Here's another one from today..https://youtu.be/vCcaPfmBG4E |
![]() | #208 |
![]() | #209 |
Moderator ![]() Join Date: Jan 2004 Location: chicago
proper way to tune emulsion style shocks is to emulsify the shock before you run it. ever see racers pump their shocks before putting the car down? thats why.
![]() | #210 |
Tried rebound and shocks had no rebound the next day after use. So screw rebound, I thicken up the oil to 40wtf/35wtr and runing zero rebound now. For the rough terrain I am running it seems to be hooking up incredible.. What battery are you running and what's your run time??? I am running a 6200mah 40c and getting a little over 20min. Also side note, ditched the avc completely and running a non avc receiver. Couldn't be happier!! ![]() |
![]() | #211 |
![]() | #212 |
![]() | #213 | |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| ![]() Quote:
I mentioned it a few pages or so ago. ^^ that steering thing? never seen that. and my truck already won a race in blown out farm dirt. | |
![]() | #214 |
Slow mo, suspensions so plush. https://youtu.be/5j16owsPd-s |
![]() | #215 |
After reading around online I seen a thread that a lot of people where having issues with their rear ends. I wasn't having any but as a preventive Measure decided to take mine apart and see what's in their.. Good thing I did!! Clean, grease/lube and back in she goes. It was bone DRy... My ring and pinion are showing some wear, dirt all inside the housing and it's got a spool!!! Going to need a new set of gears down the road and maybe sooner than later... On a lighter note losi reached out and is sending me a new steering system they want me to try out.. ![]() ![]() Spoke to soon, couple seized bearings. ![]() ![]() ![]() Last edited by TTDRIVER13; 08-01-2016 at 06:17 PM. |
![]() | #216 | |
| ![]() Quote:
Personally I hate the feeling of air bubbles in my shock oil. I'll spend hours building a set of shocks, slowly compressing and extending them, then letting them sit, getting every last tiny air bubble out. If I want softer shocks I'll use thinner oil. | |
![]() | #217 | |||
| ![]() Quote:
My gears were "lubed" with thick, sticky silicone. Better than nothing, but only very slightly better than nothing. I started getting longer runtimes after I made sure everything was properly greased. Quote:
I really like Boca Yellow Seal ceramic bearings. If you can get those to seize, Boca might send you a prize or something. I've run them through mud and water, and I even run them un-lubed in nitro clutch bells so they don't spray grease inside the clutch bell, and they just don't fail. Worth every penny if you hate replacing bearings. Last edited by fyrstormer; 08-01-2016 at 09:01 PM. | |||
![]() | #218 |
I have nothing on the steering yet but will post up when I get the parts in. Thanks for the recommendation on bearings, he is suppose to be shipping me some as well but I will keep that in mind if it's in on going problem.
![]() | #219 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Make sure to check your timing in your esc. Mine had timing programmed in from the factory.
![]() | #220 | |
| ![]() Quote:
Thanks for that, mine was turned up as well. As for the steering vertical play, this is what losi sent me. The smaller post. I still had to run the eclip behind the bearing to eliminate some of the vertical play on the threaded tower. ![]() | |
Thunder Tiger Jackal 1/10th 4wd Desert Buggy | RichMTB01 | 2.2 Scale Rigs | 17 | 01-19-2016 12:36 AM |
Vaterra 1/10 Twin Hammers DT 1.9 4WD Desert Truck RTR | spectre | Vaterra Twin Hammers | 0 | 10-01-2015 07:54 AM |
HPI Mini Trophy 1/12 Scale 4WD Desert Truck | constantmotion | Non Crawler RC's | 31 | 08-01-2010 09:56 PM |
