![]() | #2221 |
I wanna be Dave Join Date: Sep 2019 Location: US
Deleted by user. (For some unknown reason, my post got dbl-posted) Last edited by Panther6834; 06-08-2020 at 09:44 AM. |
![]() | #2222 | |
| ![]() Quote:
~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
![]() | #2223 |
Rock Stacker Join Date: May 2020 Location: Philly
Thanks. It sounds like some people have used the TLR22. There is also the Hot Racing TLR 22, which is a clamping version that is supposed to be compatible with the TLR22. So, one might think that the Hot Racing TLR 22 would also work. Am I crazy here or will the Hot Racing TLR 22 work? https://www.amainhobbies.com/hot-rac...5ltr22/p769037 |
![]() | #2224 | |
High altitude delirium ![]() Join Date: Mar 2012 Location: Fort Collins
| ![]() Quote:
They will both work, but probably replace your servo before you buy a horn so you get the right teeth count. You don't want to get one for the stock servo and then have to get another when you replace the servo! I prefer clamping horns. | |
![]() | #2225 | |
| ![]() Quote:
Thanks, but too late! I bought an aluminum 23t arm for the stock servo and the stock servo crapped out after 1.5 packs! oh well. If anyone needs it, let me know. I am getting a new 25T servo now and trying to decide what arm to get. | |
![]() | #2226 | |
| ![]() Quote:
Is there any advantage to using a 20mm long arm? Stock is 15mm (I just measured it). | |
![]() | #2227 | |
| ![]() Quote:
![]() | #2228 |
Newbie Join Date: Jun 2011 Location: London
I pulled the trigger last night and ordered one of the Last BR's I can find here in the UK. I cannot remember being this excited about a new RC car for a very long time. I appreciate I am late to the party and normally would avoid a car that looks like it may be discontinued soon, but I always wanted a IFS/SRA combination so decided to take the risk. Losi is not a well supported brand here in the UK so I am going to make a few tweaks to make it more robust from the get go and also stock up on some parts that I may need but find hard to source in a year or two. Could all of you who have owned and run one of these for a while cast your eyes over my list and let me know your thoughts? First up is a selection of parts being bought primarily for cosmetic reasons, simply because I like metal! a) GPM alloy front lower and upper arms (I have not seen much evidence in this thread or on youtube of the standard front arms being weak but they are very much on display and I simply want them to look cool). b) GPM rear lower suspension... as above Next up are parts that seem to address weaknesses that can arise after time c) Steel upper arms for rear suspension. Probably GPM or Vanquish d) Hot Racing or SSD third member for SRA with big bearings e) SSD Front Bulkhead with larger bearings f) GPM alloy servo mount[/URL] g) GPM alloy stearing set I plan on sticking with the standard suspension and link mounts, figuring it is better for them to bend or even break in an impact. The same thinking sits behind retaining the standard front knuckle arms. So please let me know if there are any upgrades I have missed out that would be worth it if I hope to get a decent long life out of this beauty. And also what standard Losi spares would you keep in your parts bin? Finally I do love alloy wheels but it seems that there are no SC wheels made in alloy. Am I restricted to Proline Protrac as the only other wheel out there? thanks in advance for your thoughts and input. |
![]() | #2229 | |
| ![]() Quote:
I'm a noob, but I just got a Baja Rey (one of the last ones I could find in the US) and my servo lasted 1.5 packs, so you'll definitely want to add a better one to your list. I just ordered a Savox and a 25T horn, which was almost impossible to find. I also installed an SSD third member and checked the gear mesh before even running it. I found lots of grease in the rear. This contradicts what I read in older posts about the rear being dry, so apparently Losi fixed that issue. I got a spare ring and pinion just because people have blown theirs up and they were also very hard to find, so when I found one, I grabbed it. I really hope the parts shortage is related to COVID and not something else. Does anyone know why there are so few parts? If you'll be running on 3S, the front tires will balloon very badly. I just dismounted my front tires last night to see if Gorilla tape will help. Seems like a lot of people have success with it. Good luck! | |
![]() | #2230 |
Newbie ![]() Join Date: Dec 2016 Location: holapa
I bought a Baja Rey about 3 months ago, and it has been more difficult to get sorted than any RC I've ever owned. Challenges so far: -- grinding noise on any hard acceleration or braking Tore into all three diffs (front/center/rear) to inspect gears, and all were 100% ok. Replaced front diff case with exotek metal case just to be extra safe. Put everything back together, and problem was still there. Replaced rear diff gears with Losi diff locker and problem went away. So there is something wrong with the rear diff gears, but I'm not sure what. I have a metal third member which I can install, but so far the rear axle is stock. -- won't turn left Tested a different (known good) servo on the bench, and it clearly showed the problem. Throw to the right was fine, throw to the left was about 30%. I replaced the receiver and transmitter with a basic unit I had lying around and immediately had full throw in both directions. Have other folks had any such problems? |
![]() | #2231 |
Yeah, my servo lasted 1.5 packs. No grinding noise here, but I installed an aluminum 3rd member before even running it.
![]() | #2232 |
Alright, so I fixed the crazy ballooning of the stock tires on 3s. I cut a width of Gorilla tape the exact width of the tread and taped the insides after scuffing the tires' inside surfaces. I overlapped the end 1/2", then added another piece of tape 1/2" long 180 degrees from the overlap for balance. I then CA'd all the way around both edges of the tape and all joints with the tire not inside out. The beads of CA are at the 90 degree angle where the inside of the tread surface meets the sidewalls. I figured that would add a lot of strength to the tire overall. Let it dry overnight, reasembled, and glued. I have run a few 3s packs through it since and there is absolutely no ballooning at all. I can't even see the tires expand a little bit. I'm pretty happy about it. I hope it lasts! I also took the opportunity to paint the beadlock rings silver to match the paint of the Black Rhino body and it looks killer.
![]() | #2233 | |
| ![]() Quote:
![]() | #2234 |
The original Baja Rey had a locked rear diff, but the new one has an open rear diff. Which do people prefer and why?
![]() | #2235 | |
| ![]() Quote:
For my BR, I wanted to create something very close to a limited-slip, with just a slight bias towards the 'slip', so I decided to go with 80K. I could have removed a little of the 'slip', and gone with 100K, but I felt that 80K would handle slightly better in turns...and, so far, it has. ~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
![]() | #2236 |
Thanks Panther. Do you have any trouble keeping the oil in the diff? Because of the way the axle shafts enter the diff, I have trouble with leaks...
![]() | #2237 | |
| ![]() Quote:
Before placing the gears inside the diff cup, I put some waterproof grease in the bottom opening (from the outside). I did the same thing to the ring gear (which is also the diff 'cap'). This acted as a temporary "plug", allowing me to add the first gear, add some diff fluid, add the planet gears, and then more diff fluid, without losing any fluid out the bottom. I figured, there was also the possibility that, once the axle was fully assembled, the waterproof grease might also help to keep the fluid inside the diff. If I remember, I'll report back the results of the rear axle. ~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
![]() | #2238 | |
| ![]() Quote:
![]() ![]() ![]() As for your initial question, here's your answer: ![]() ![]() ![]() As you can see, the waterproof grease I used to "plug" both ends of the diff is holding up EXTREMELY nicely. It doesn't appear as if any diff fluid has exited the diff. ~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
![]() | #2239 |
Panther, are those 125mm RC Run shocks?
![]() | #2240 |
| ![]() I bought them on eBay. The brand want listed, but that's what the sticker on the piggyback says. On eBay, they're just listed as '4pcs 123mm Negative Pressure Hydrolics Shock Absorber for 1:10 RC Car Model'. They were $65.99 for 4 shocks. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
Thunder Tiger Jackal 1/10th 4wd Desert Buggy | RichMTB01 | 2.2 Scale Rigs | 17 | 01-19-2016 12:36 AM |
Vaterra 1/10 Twin Hammers DT 1.9 4WD Desert Truck RTR | spectre | Vaterra Twin Hammers | 0 | 10-01-2015 07:54 AM |
HPI Mini Trophy 1/12 Scale 4WD Desert Truck | constantmotion | Non Crawler RC's | 31 | 08-01-2010 09:56 PM |
