06-16-2020, 11:11 PM | #2241 | |
Pebble Pounder Join Date: Mar 2012 Location: Fort Collins
| Re: Losi Baja Rey 1/10th 4WD RTR desert truck Quote:
Great, thank you for the info!! | |
06-16-2020, 11:42 PM | #2242 |
Newbie Join Date: May 2020 Location: San Diego
Do they make aluminum shock ends? The bottom part of my rear shock ripped out of the plastic end link that goes into the rear arm. It still threads back on and appears strong, but after a good crash it will pull out again.
06-16-2020, 11:48 PM | #2243 | |
I wanna be Dave Join Date: Sep 2019 Location: US
Among my vehicles, I also have a Rustler 4x4. Over the past 1.5 years, I've done several upgrades to it...including replacing the stock 3500kV motor with something a bit more powerful (if you consider a 4100kV motor just a "bit more powerful"). While I did do some initial testing after reaching various points in the upgrading, I had only tested on 2S...I never got around to testing on 3S. Then, I took it with me to Vegas, to run with my step-dad's Slash. I decided to pop in a 3S, so he could see what she could do. To make a long story short, she did an absolutely amazing aerial acrobatics feat...a "perfect 10", if you ignore the landing...and, by the time I retrieved her, the front passenger-side A-arm & steering were no longer attached to each other. I don't blame the part for being 'weak'...it was my driving that led to the damage. ~ More peace, love, laughter, & kindness would make the world a MUCH better place Last edited by Panther6834; 06-17-2020 at 12:01 AM. | |
06-17-2020, 12:09 PM | #2244 |
Rock Stacker Join Date: May 2020 Location: Philly
I broke a front outdrive, so I need to pull the front diff apart. Can someone recommend an oil weight for the front diff? My center and rear diffs have the factory oil in them now if that matters. Do we even know what weight oil these trucks came with? Any recommendations for center and rear diff oil weights while I'm thinking about it? Seems like some people like a thicker oil in the center, but what is considered thicker than stock?
06-17-2020, 01:33 PM | #2245 | |
Newbie Join Date: Dec 2016 Location: holapa
front: 30k center: 300k rear: locked (with a locker) So far it is interesting... I am thinking of going back to unlocked gear diff with a small amount of diff putty (don't want to deal with leaking). The putty is less precise than oil, but if you start with a small amount you can still get some control. The benefit is no leaks ever - it just sticks to the spider gears. | |
06-17-2020, 05:07 PM | #2246 | |
Now that I think about it, I probably should have re-greased the rear ring gear...guess I'll be opening her back up tomorrow. A man's work is never done. ~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
06-17-2020, 05:49 PM | #2247 | |
Thanks! But hey, at least greasing the rear is easy. I'm about to do a ring and pinion job on a 1:1 car and I'm kind of not looking forward to it at all. I am looking forward to the results, though! | |
06-17-2020, 11:41 PM | #2248 | |
Thanks for the cool story though "thumbs" | |
06-17-2020, 11:53 PM | #2249 | |
06-18-2020, 09:56 AM | #2250 |
Does anyone have any Exotek diff gear cases (EXO1843) that they would like to get rid of? Looks like everyone is sold out.
06-22-2020, 07:57 PM | #2251 |
Newbie Join Date: Jun 2020 Location: US
Getting prepped for the rest of my upgrades. So far just front shock tower and servo mount. Will post pics once completed. Sent from my LM-V600 using Tapatalk |
06-23-2020, 07:15 AM | #2252 |
Some people like to grease the front diff, but what are they going for? Are they just putting a light coating of grease in to provide a lot of differential action or are they packing it full to almost lock it, similar to putting a very heavy oil in? Why would someone want to use grease instead of a very viscous (heavy) diff oil?
06-24-2020, 11:25 AM | #2253 | |
Pebble Pounder Join Date: Jun 2008 Location: Modesto
McMaster Carr | |
06-24-2020, 05:34 PM | #2254 |
Anyone having trouble with wheels in the front interfering with the fenders? I'm getting a lot of interference on turns...
06-24-2020, 06:21 PM | #2255 | |
That’s why I decided to design my front like this… Last edited by CaliCrawler; 06-24-2020 at 06:23 PM. | |
06-24-2020, 07:17 PM | #2256 |
| Re: Losi Baja Rey 1/10th 4WD RTR desert truck |
06-24-2020, 07:22 PM | #2257 |
06-24-2020, 07:27 PM | #2258 | |
06-24-2020, 07:31 PM | #2259 | |
And sorry I’ve been Gone so long! But in contrast, I do love the KR2s on the UDR! Go figure… Last edited by CaliCrawler; 06-24-2020 at 07:36 PM. | |
06-24-2020, 08:10 PM | #2260 | |
Losi Baja Rey 1/10th 4WD RTR desert truck - Similar Threads | ||||
Thunder Tiger Jackal 1/10th 4wd Desert Buggy | RichMTB01 | 2.2 Scale Rigs | 17 | 01-19-2016 12:36 AM |
Vaterra 1/10 Twin Hammers DT 1.9 4WD Desert Truck RTR | spectre | Vaterra Twin Hammers | 0 | 10-01-2015 07:54 AM |
HPI Mini Trophy 1/12 Scale 4WD Desert Truck | constantmotion | Non Crawler RC's | 31 | 08-01-2010 09:56 PM |
