05-26-2017, 04:29 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| New motor
Soooo I got my new motor and the feckin shaft is about 8mm to long do I cut it with the trusty dremell or pack it of the motor mount with mm washers ??? Hmmmm ??? Sent from my iPhone using Tapatalk |
05-26-2017, 06:28 PM | #2 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: New motor
Is that the new Castle grayish/blueish motor? the sensored one? BTW, I really like your rig dude. |
05-26-2017, 06:33 PM | #3 |
| Re: New motor
Thank you el fernando trying to make it my own and no it's the mean green standard can 1410-3800kv sensored I couldn't wait for the crawler lol basically the same thing tho Sent from my iPhone using Tapatalk |
05-26-2017, 09:39 PM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: New motor
I would cut the motor shaft over spacing the motor out.
05-26-2017, 10:19 PM | #5 |
| Re: New motor
I'd cut it. ...and don't use a bench grinder; don't ask why I know. I think a cutoff wheel on a dremel would work fine. Just be mindful of how hot the motor shaft is getting, letting it cool as needed. What ESC will you be running? |
05-27-2017, 12:42 AM | #6 |
| Re: New motor
That was exactly my thinking , I was just a bit reluctant to go cutting things that I'd just ordered and waited 3 weeks to be delivered lol Buuuut all good and well and running like a dream , iv got the mamba x and it's a thing of beauty and so is the sensored motor my field link didn't like it tho it was lit up like a pin ball machine , i think it just needs Sent from my iPhone using Tapatalk |
05-27-2017, 12:43 AM | #7 |
| Re: New motor
An update , lil children's fingers posting half written replys lol Sent from my iPhone using Tapatalk |
08-19-2018, 12:12 PM | #8 | |
Newbie Join Date: Jul 2018 Location: 'BURBS OF NYC
| Re: New motor Quote:
Hi Willyg1982. Did you end up cutting the tip off? Has anyone else experienced the same issue with their motor? I just wanted a month for the Castle 1415 2400Kv with 5mm shaft Mamba X combo to arrive and the motor shaft looks to be a tad too long to fit in the housing. It really hurts to think I need to cut something of this beauty even before it get plugged in for the first time. Does the dremel get to see a little action today or are there better alternatives? Thanks. | |
08-19-2018, 12:20 PM | #9 |
| Re: New motor
Hi BMPNGGRND, Yes I felt the same before cutting but yes I did cut it others have dealt with it in different ways , 1) loosen the plastic housing away from chassis plate and try wiggling it in ( I have heard this does work ) 2) drill a small hole to allow the shaft to stick out the back and make or find something to cover the shaft like the rubber removable cover found on the twin hammers slipper clutch assembly 3) just cut it ,..... It’s not that much to cut off ( approx 5-8 mm ) and since cutting it I have now replaced that specific motor and fitted it in the Gom and it wasn’t too short at all , so I wonder if the motor shaft was just a bit too long in the first place Hope that helps Sent from my iPhone using Tapatalk |
