Ssd aluminium bulkheads Our prayers have been answered !!! https://uploads.tapatalk-cdn.com/201...b47b103286.jpg Sent from my iPhone using Tapatalk |
Re: Ssd aluminium bulkheads Awesome! A little birdie told me about that a few weeks ago, but without an ETA. It's priced right where I had anticipated too, so I'll be ordering one for my Baja Rey as soon as they are available. |
Re: Ssd aluminium bulkheads Holy shat, I thought we would never see one. And upgraded bearings too, thank god!! |
Re: Ssd aluminium bulkheads Holy crap! That is fricken fantastic news! SSD you're a champ mate! One SSD rear member and a bulkhead coming up! The best thing now is that the RR/BR will take 3S but it'll also be a tougher truck for bashing hard on 2S. This has cemented my ideas for my RR. I'm going to get a sensored system for it for sure now. There will be a number of Christmas requests definitely! |
Re: Ssd aluminium bulkheads Really hope I can get my hands on one when it releases. Going to be pretty popular! Signed up for email notifications when it does release. |
Re: Ssd aluminium bulkheads For anyone wondering, no black verison and bearings are 5x13 inner and 5x11 outer. "thumbsup" |
Re: Ssd aluminium bulkheads for me the big problem with the full locked or rear and middle diff locked is the front cv drive shaft and not the bulkhead . In plastic they twist and broke and in hot racing version they broke at the first 3s pack.But it's a nice part hope the BJ CVD gone a be enough strong.Now I'm thinking about only locked the middle diff to see if it's not good I'll go back to stock set up. argl out of stock |
Re: Ssd aluminium bulkheads You should try some racers edge diff lock putty. Works really good, but still has some give if needed. Also, did you try putting some M6 grub screws in the stock plastic shafts? That's what I did. |
Re: Ssd aluminium bulkheads thanks for the tricks gone a try the screw .With putty is there still a little motion in the diff in case of or it's completely locked.But today I m unlocking (middle still locked) the rear try it and see. |
Re: Ssd aluminium bulkheads It acts locked very good but if needed, you can spin the tires opposite direction by hand. Its really the best option if you want locked diffs without broken parts. |
Re: Ssd aluminium bulkheads ok that s the way I'm gone follow . I forgot on the rear axles shafts end are square so I can't not put a front diff on the rear the hole is larger than the square of shaft.So I ride it with middle and rear much better in my point of view than full locked especially at high speed (ride a 3200 kv/550 with 11 teeth pignon and 100k ultimate racing silicon oil in front diff)can now squeeze the trigger at full throttle |
