Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Losi Rock Rey
Thread: Baja rey front shock tower vs Rock rey
Old 09-21-2017, 06:29 AM   #1
Default Baja rey front shock tower vs Rock rey
Ive looked at as many pictures that show a decent view of the front. My question is does the baja rey front shock tower share the same geometry as the rock rey?
I am on my third front stock shock tower and at this point the aluminum upgrade is starting to look tempting. I dont see why there would be any difference as far as I can tell they use the same shock, other than appearance. I figure with TLR shock tower, SSD case, and HR vaterra diff cup I should have a near bullet proof front.
Thought and opinions?
Mark
jumper is offline   Reply With Quote
Old 09-21-2017, 10:00 AM   #2
Default Re: Baja rey front shock tower vs Rock rey
If you've broke 3 so far, send emails (with pictures) to hot racing and rpm.
As far as I know, front shock towers won't work.
84yoda is offline   Reply With Quote
Old 02-07-2018, 05:52 PM   #3
Ok so i just did the RR front shock tower to my BR... i had to cut the stock br down enough for the rr tower to clear over. And you use the hinge pin for the a-arm and trim a little off the rr tower for it to fit in snug longer shocks are needed im using rear yeti shocks rn for mock up
Sent from my SM-A520W using Tapatalk
Kronix is offline   Reply With Quote
Old 02-07-2018, 07:21 PM   #4
that's interesting thanks for the pictures, since the BR has different suspension upfront I think the BR shock tower will be an easier fit, plus it would give a little bit of lift since you said you needed longer shocks. I am going to pick up a plastic BR shock tower since they are cheap and see what happens.
Baja rey front shock tower vs Rock rey - Similar Threads
Sneak peek! SSD HD Front Bulkhead for Rock / Baja Rey coming soon! RPP Hobby RPP Hobby 1 09-14-2017 10:16 PM
VP Currie F9 Axles for Losi Rock Rey and Baja Rey - In Stock! RPP Hobby RPP Hobby 0 04-27-2017 01:29 PM
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! RPP Hobby RPP Hobby 4 03-22-2017 04:30 PM
Added section for Baja/Rock Rey Wes S. Comments, Suggestions, and Help 2 01-04-2017 09:28 AM
