10-15-2017, 09:40 PM | #1 |
Newbie Join Date: Jan 2017 Location: Minneapolis
| Diff gear question?
Can someone please measure the ring gear diameter for me. I'm wanting to know if Ray gears will fit in a twin hammer. So many other diff parts seem interchangeable. |
10-16-2017, 09:55 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: Diff gear question? hope this helps Sent from my iPhone using Tapatalk |
10-16-2017, 05:06 PM | #3 |
Cheers! The TH ring is 32.3 so it's close. I see the rey pinion has a shoulder that could be cut to adjust the fit. It could work. |
10-16-2017, 05:10 PM | #4 |
I'd say it's most likely exactly the same and that's only .1 of a mm difference good enough to say it's a straight swap I think the hammers has a higher tooth count if I remember correctly ? Sent from my iPhone using Tapatalk |
11-01-2017, 10:27 PM | #5 |
The twin hammers gears are actually only 32.2 diameter, so the rey gears are a tight fit. Works great in the integy case, but not in the stock one. This would give the rey a second ratio choice too. |
Diff gear question? - Similar Threads | ||||
Diff Pinion gear Question With Vid | pro mod steve | Axial Yeti XL | 20 | 04-08-2015 03:54 PM |
Diff gear question | mudweaver | Axial Wraith | 5 | 02-26-2015 03:38 AM |
Robinson Racing Outdrive diff gear question | Hirschowl | Axial SCX-10 | 11 | 06-09-2014 09:42 AM |
IFS diff gear question | J5races | Axial Wraith | 2 | 05-06-2014 08:43 PM |
