10-29-2017, 06:17 PM | #1 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Weak point on the Rock Rey
I'm thinking in buying the rock rey kit in this coming Christmas. But quickly search and found they're using smaller input pinion shaft bearings ( 5x10 ) just like my Axial Wraith. So disappointed, You need to modify the axle housing to accept the bigger bearings( 5x13 ) for more durability under 3-4s power. Any aftermarket big bearing axles coming out yet? or someone has did the big bearings modified? Thank you |
10-29-2017, 06:23 PM | #2 |
| Re: Weak point on the Rock Rey
The Gmade GOM's axles used bigger bearings ( 10x15x4 ) However, I already had many frond solid axles rigs. So now I need independent front suspension rig for more stable high speed bashing. |
10-29-2017, 07:03 PM | #3 |
SSD makes an aluminum front housing that uses 5x13 inner and 5x11 outer pinion bearings. SSD and Hot Racing make rear 3rd members that use 5x13 pinion bearings, Metal Concepts makes a 3rd member/truss combo that uses 5x11. Vanquish makes a rear axle housing that uses 5x14 (?) pinion bearings, and RC4wd makes a rear axle housing that uses 5x13(?) bearings.
10-29-2017, 07:11 PM | #4 |
Thank you TheLetterJ. What a good news, I will check out these vendors. I am off to work now. Thank you so much mate. Cheers |
Weak point on the Rock Rey - Similar Threads | ||||
Baja rey front shock tower vs Rock rey | jumper | Losi Rock Rey | 3 | 02-07-2018 07:21 PM |
VP Currie F9 Axles for Losi Rock Rey and Baja Rey - In Stock! | RPP Hobby | RPP Hobby | 0 | 04-27-2017 01:29 PM |
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! | RPP Hobby | RPP Hobby | 4 | 03-22-2017 04:30 PM |
New weak point? | totallypro | Axial Yeti | 9 | 06-11-2015 08:37 AM |
Weak point | sullysracin | Newbie General | 7 | 01-08-2010 03:31 AM |
