02-25-2018, 05:12 PM | #1 |
Newbie Join Date: Nov 2013 Location: Tampa, FL
| Blown front gears
I just blew my front gears. I locked my center diff, and each time I landed from a jump, it made a "gear stripping" sound. After looking at the web, someone stated that the factory open diff in the center acts like a slipper clutch, is there some truth to this? Is there a way to add a clipper clutch after locking the center diff? Either way, looks like I'm getting the SSD aluminum bulkhead and a new set of gears. |
02-25-2018, 05:57 PM | #2 |
| Re: Blown front gears
FYI, the gears are at a great price on Amazon at the moment, but the system is having issues not letting me place an order.
02-26-2018, 09:50 PM | #3 |
Pebble Pounder Join Date: May 2015 Location: UK
A center diff does behave like a slipper, in fact it's way better than a slipper in many respects but not so good for crawling. Unless someone makes a slipper for it, there's no way of adding one. I doubt the space layout inside would allow one either.
03-03-2018, 07:15 PM | #4 |
I thought it was a stripped ring and pinion... nope, it's the carrier screws. Traxxas 2523 screws have been ordered. |
03-03-2018, 10:39 PM | #5 |
You might as well add Hot Racing #VTH11C to your order. Being that your screws are broken, there's a high likelihood that the screw holes in the plastic diff cup are also fubar'd, the above part is an aluminum diff cup/carrier (meant for a Twin Hammers) that is a direct drop in replacement. Between the SSD bulkhead, hardened screws, and aluminum carrier, the front diff is as reliable as it can get.
03-04-2018, 08:02 AM | #6 | |
Newbie Join Date: Oct 2008 Location: Burbs
| Re: Blown front gears Quote:
I’ve been looking all over. As of last week the HR Diff Cup is on backorder. If you find a place that has them in stock please let me know. Sent from my iPhone using Tapatalk | |
03-05-2018, 08:15 AM | #7 |
Same here, no luck finding them in stock. I was given advice that the Traxxas screws with stock Losi carrier has been solid. |
Blown front gears - Similar Threads | ||||
Front differential gears available? | Phylodog | Vaterra Ascender | 3 | 01-29-2017 05:13 PM |
Broken Gears/blown bearings - Pictures | R2theICKY | Axial XR10 | 28 | 09-15-2010 02:01 PM |
Blown front end | woodymaxx | General Crawlers | 0 | 07-30-2006 05:28 PM |
