03-14-2018, 06:55 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Fallon, NV
| BR Front Diff outputs
I just got a Baja in a trade and it has a broken front diff output. Looking at the exploded views of the BR and RR I'm thinking that i should be able to use the RR outputs and axle shafts on the BR. Has anyone tried this or have any supporting info as to good or bad idea? I was told by the previous owner that this is the second output he broke it has pro-line shocks on the front and i figured the arms were dropping to far but the side that's not broke doesn't seem to bind at full droop. Thanks for the help in advance
03-14-2018, 07:27 AM | #2 | |
Quarry Creeper Join Date: Dec 2010 Location: Pontypool, wales
| Re: BR Front Diff outputs Quote:
If your asking whether or not you can use Rock Rey drive shafts and Rock Rey outputs in the baja then yes it would work in theory looking at the exploded view , however you may find that the RR drive shafts when at full compression are too long but that would only be a bit of grinding and cutting , If your asking could you use RR outputs in the BR using its stock dog bones then no as they are totally different design Sent from my iPhone using Tapatalk | |
03-14-2018, 07:35 AM | #3 |
that was my thought as well, the bearings are the same size on the diff side and knuckle side. was just looking for verification before dropping $100 to convert (RPP prices) Looking at the setups I believe they are different due to the RR having front swept A-arms and the dog bone setup would bind
BR Front Diff outputs - Similar Threads | ||||
Front Diff to use as Rear Open Diff | ongbenghui | Vaterra Twin Hammers | 5 | 03-02-2017 12:54 PM |
Front axles and outputs | camperwill | Axial Yeti | 26 | 10-25-2016 06:13 PM |
Front diff outputs part | camperwill | Axial Yeti | 1 | 10-22-2016 08:39 AM |
Play between front and rear outputs on transmission? | cizardev | Vaterra Ascender | 14 | 01-28-2016 10:04 AM |
Maverick Scout weak diff outputs, possible resolution? | Dusterfluster | Newbie General | 1 | 06-08-2015 04:12 AM |
